Sure Electronics Tripath boards?
Old 24th September 2012, 05:58 PM   #931
prezden is offline prezden  Canada
Hi QT
Thanks for the link- I had looked at it before but didn't realize it was the new version of the board. Could you kindly tell me which caps you used and exactly where you soldered them in. Also did you remove and caps or resisters as per the old board mods.
cheers- preston
Old 24th September 2012, 08:35 PM   #932
QT0815 is offline QT0815  Germany
Originally Posted by prezden View Post
Hi QT
cheers- preston
I have to quote myself here
Then i changed C22 and C30 against 2,2uF MKP from WIMA.
There you could also see, where i added caps for the supply.
I removed the ceramic caps, and soldered these 2,2uF caps on the solderpads. But be really careful, bend them as good as possible. Then i fixed everything with hot glue. If you bend these a little, the solderpad might come off quite easily! You also might add some of the caps for stabilising the power supply a little. Might help a little with deep bass. I drive 2 16cm speakers in my car, and the bass /highs are better than with the integrated amp from my poineer radio. Not much louder, but sounds fine with CD's. But the tripath amps are surely jam my radio - a lot!
Old 24th September 2012, 09:01 PM   #933
Thanks QT- that's just what I needed
Old 24th September 2012, 09:33 PM   #934
Thats fine, please show some pics if finished...
Old 24th September 2012, 10:54 PM   #935
Well- it might take a while. I destroyed the one I had taking off the wrong resistors. There are a couple new ones coming from Sure.
Old 16th April 2014, 08:14 PM   #936
bestbier is offline bestbier  Netherlands
Does anybody know which ones the input caps are in this new Sure amp? I would like to replace them whith some really good ones, and I don't think that SMD caps are the best ones.
Old 23rd April 2014, 03:38 PM   #937
https://www.flickr.com/photos/27957861@N08/13901842034/
https://www.flickr.com/photos/27957861@N08/13901429645/
https://www.flickr.com/photos/27957861@N08/13901594073/
Old 6th August 2017, 12:46 AM   #938
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
Anyone have one of the first generation TA2024 boards from Sure, AA-AB012 ver 1.1 for sale?
Old 5th October 2017, 08:58 AM   #939
fabien44 is offline fabien44
Hello,
i am looking for TK2350 assembled board. Where can i find one?
Old 5th May 2018, 04:48 PM   #940
starbender is offline starbender
Just got the sure ta2024. Board seems working but both channels have some kind of distortion. Not hiss, not crackling noise or anything. It's more like scratchy sound.
I checked the speaker outputs and there is 50khz signal with or without input.
Other than this disturbing noise board sounds promising.
Any idea what the problem might be?
Sure Electronics Tripath boards?Hide this!Advertise here!
