Go Back   Home > Forums > Amplifiers > Class D
Old 18th November 2007, 03:58 PM   #1
Default Krell KSA change
I use a Krell KSA 50 matching to my Magneplanars 3.3/R since five years; now I would replace it with a UcD 700 HG, but I'm not sure of the change. Someone could give me an advice? Do you believe that UcD would be better than Krell?
Thank you
Leandro
Old 22nd March 2008, 10:48 AM   #2
umut1001's Avatar
i dont believe..a class D amp can never sounds well than class A
Old 22nd March 2008, 12:51 PM   #3
http://recforums.prosoundweb.com/ind...965#msg_320125
Jan-Peter
Old 22nd March 2008, 02:18 PM   #4
umut1001's Avatar
i think they are not musicians
Old 22nd March 2008, 03:30 PM   #5
ajazz is offline ajazz  India
ecodoppler
Just go ahead with the change.
UCD will give you much better defination & clarity.
umut1001
If you are a musician I suggust you listen to one first.
It will definately change your impressions regarding ClassD
Old 22nd March 2008, 03:43 PM   #6
AndrewT is online now AndrewT  Scotland
well, I'll be a dodo.
I'll stick with a good ClassA anytime.
And I won't even bother with listening to a ClassD design, good or bad.
regards Andrew T.
Old 22nd March 2008, 04:54 PM   #7
I think you require a blind test or may be u prefer to live in the stone age.
Old 22nd March 2008, 05:34 PM   #8
that's why I'm like the dodo. I have no intention of ever letting a ClassD amp near my analogue ears.
regards Andrew T.
Old 22nd March 2008, 05:53 PM   #9
What's your input anyway?
are you still stuck with your old vinyl records & cassette tapes.
So finally digital In and analoque Out for your ears.
Old 22nd March 2008, 07:23 PM   #10
umut1001's Avatar
Default andrew
hi i am an electronics engineer and a 250watts class D amp was my graduating project..i now a lot about Class D..i am agree with andrew..a good Class A is better than class D..and i listened to mory cante yeke yeke record and it was very beautiful than cd..analog is still better..but maybe in future digital will be better..hi andrew..have you ever made a Class A mj amp? my friend did it and says it is the best class A.. have a look..this site contains hi-end documents.. http://www.cooltune.ch/Projects/Megalith01.htm
i will try this amps..we can discuss..
Need a change Vivek Multi-Way 2 25th April 2008 06:41 PM
name change Juergen Knoop Forum Problems 2 25th October 2007 08:50 AM
just what to change? AX-100 freakyone Pass Labs 9 9th September 2006 09:59 AM
qts change Ilianh Multi-Way 3 30th November 2002 09:26 PM
Page generated in 0.11522 seconds (68.67% PHP - 31.33% MySQL) with 10 queries
