| Class D Switching Power Amplifiers and Power D/A conversion |
#81 | |
I received my amp yesterday and have had some time to play with it. I used a 15v 4A laptop power supply for some low volume tests but I have ordered a 13.8v DC 12A Regulated Switching Power Supply as well as a 12VDC 29A Regulated Switching Power Supply both from Sure Electronics. I'm (spanking) new to amplifier building and was initially interested in this Amp due to its size and efficiency ( being cheap was certainly a bonus) Some one asked the question earlier if this amp can be bridged. The answer that was the posted was Quote:
What is the physical wiring required to achieve this? I will be using this with 2 Carlsbro NlighN NXT flat panel speakers and powering with other speakers with my big amp. The amp and the power supply will be built into a 1U 19 inch rack. Thanks |
#82 | |
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#83 | |
#84 | |
So if I wanted to power a 4ohm sub, I could simply use two channels for twice the power? Would you use a resistor for both + and - speaker outs? Or is it wired in parallel? Does this change the impedance at all? Also, am I right in thinking this amp is 2 ohm stable? It mentions 2 ohm on the e-bay page ("150W 4CH C 2"), but I want to be sure I don't kill the amp by running it at 2ohm (been there, done that, cheap crappy car amp thankfully)... EDIT: Class D student, I think you will get more power out of this amp running it at 24v instead of 12v... Don't quote me on that tho.
#85 | |
Thanks for your reply Workhorse, thats helpful. What will happen if there is a difference (between ch 1 & 2 fro example) in line-in level if I am bridging them. Possible damage? |
#86 | |
#87 |
Account Disabled
anyone actually measured the power output of this amplifier?
does it have any easy way of bridging two channels? and... http://mysite.verizon.net/windup/p/s/2.jpg is this the actual build quality? because that soldering looks gross, you'd think they would atleast clean up the flux residue. |
#88 | |
Seriously, would you be so kind as to share your component list. I am new (dumb Thanks |
#89 | |
...or running windows... |
#90 | |
| MM Electronics Paice amps??? | burningbushhifi | Solid State | 7 | 6th July 2011 01:46 PM |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Page generated in 0.14321 seconds (76.86% PHP - 23.14% MySQL) with 11 queries |
