Full Digital Speaker
Old 5th November 2007, 01:29 AM   #21
KOON3876 is offline KOON3876
Hey any positive reaction?
like "Yes go for break it! I want to look you screwed up!"
I have no interest about practical or not. Just want to DIY something freak
Now finished schematic, attached is BOM. Not so expensive than I thought.
Old 5th November 2007, 09:14 AM   #22
TheShaman is offline TheShaman  Europe
I have attached a picture of an early prototype...
They are still working on it, of course, but its sound is pretty decent. Promising work.
Koon, go for it mate! It certainly is an interesting project.
Old 5th November 2007, 04:35 PM   #23
lne937s is offline lne937s  United States
Default dominate
I would love to see this work.
Maybe using something like this for drivers....
http://www.getmad.com/mad_a8.html
Old 5th November 2007, 06:41 PM   #24
Pano is online now Pano  United States
Pano's Avatar
By all means go for it!
We are just trying to tell you it's a lot harder than you think. If it weren't, these things would be all over the place.
But do build one, it's such a cool idea. I tried and failed, but that doesn't mean that you will.
Take the Speaker Voltage Test!
Old 9th November 2007, 04:10 AM   #25
Thank you!
If it's easy, no value to DIY.
60 drivers arrived. OMG...
Old 9th November 2007, 04:12 AM   #26
One block (2 bit in and out) of board. 2x1.4 inch.
I have to copy this 26 times.
From left,
Analog switch and LPF R&C
Differencial Amplifier Rs
OpAmps, Top Differencial Amp & driver, for 1bit, mid 2 LPF, Bottom other bit.
Power Capacitors,
TR and bias Diodes, Rs.
Old 9th November 2007, 11:44 AM   #27
luka is offline luka  Slovenia
luka's Avatar
Hi
Only 26 tmes ?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 27th November 2007, 07:14 AM   #28
Finished board layout.
too huge..
http://koonlab.com/DigiSP.html
Old 29th November 2007, 06:40 AM   #29
I wrote board but too complicated, too large. It should be more simple.
Let's make 5V single supply circuit.
amplifier section will use TPA311, TI's small amplifier.
I need voltage reference, and positive/negative side driving voltage.
Attached circuit can make 1/2Vdd adjusted positive/negative driving signal. (one switch will supply driving signal to each bit section).
Then each bit section can be driven single 5V power supply.
(switch selects between 1/2Vdd and driving signal)
Old 5th December 2007, 06:07 AM   #30
Here is ver.02 schematic.
http://koonlab.com/DigiSP/DSP_SCH02.pdf
Now all circuits work on 5V single supply, amplifier section was changed to TPA2005, TI's small Class D amplifier.
Full Digital SpeakerHide this!Advertise here!
Power DAC (like Wadia) full digital amp KOON3876 Class D 21 24th March 2011 04:08 PM
The Full Digital AMP cac liu Class D 29 27th July 2009 09:07 PM
d2audio Full digital audio okkyn Class D 4 1st August 2007 06:17 PM
Tube Output Full digital Amplifier KOON3876 Class D 8 14th December 2006 06:54 PM
full (low cost) digital chain raxy Digital Source 0 17th October 2004 11:26 AM
Copyright ©1999-2017 diyAudio
