3 Level PWM
3 Level PWM
Old 13th May 2012, 03:38 AM   #11
Workhorse is offline Workhorse
Workhorse's Avatar
Originally Posted by phase_accurate View Post
I once made simulations with a tri-state delta-sigma topology that looked very promising. Never tried it in practice though. Yours seems to be a bit similar.
Properly implemented it would have advantages like lower switching frequency, lower RFI levels, improved loop stability, reduced supply pumping and decreased body-diode conduction problems - compared to two-level delta-sigma amps.
Charles
Charles,
How can you say that body diode conduction will be reduced in 3-level modulation as compared to 2-level modulation?
regards,
Kanwar
Old 13th May 2012, 09:52 AM   #12
Pafi is offline Pafi  Hungary
Agree! Diode conduction problem depends on output topology, not modulation method.
Old 13th May 2012, 10:26 AM   #13
phase_accurate is offline phase_accurate
The whole was depending on a single-ended three level output stage and the preferred way I would have implemented it would give some relief regarding reverse-recovery.
Charles
Old 13th May 2012, 12:25 PM   #14
Workhorse's Avatar
Charles,
What would be that preferred way, just like the autoformer [referring to your cross-conduction reduction technique thread]at switching node?
regards,
Kanwar
Old 14th May 2012, 06:38 AM   #15
No it would have been a "real" three-level output stage.
Charles
Old 8th August 2013, 10:41 AM   #16
Workhorse's Avatar
Charles
Charles,
You mean using series schottky or i am missing something?
regards,
Kanwar
3 Level PWMHide this!Advertise here!
Convert Line Level to Electric Guitar Level miallen Instruments and Amps 4 16th May 2010 01:22 PM
Speaker level to line level converters qguy Subwoofers 2 9th December 2007 03:58 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
