full bridge selfosc class d amp
Old 28th October 2007, 01:14 PM   #1
Tekko is offline Tekko
Banned
Default full bridge selfosc class d amp
Heres yet another new idea i have this is for a subwoofer amp.
schematic
What do you think ? Suggestions for improvements are welcome.
Old 28th October 2007, 01:20 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This is not self oscillating.
I use to feel like the small child in The Emperor's New Clothes tale
Old 28th October 2007, 01:42 PM   #3
Banned
hum i donīt see a carrier generator around
Old 28th October 2007, 02:47 PM   #4
Eva's Avatar
Ok, I give up...
Old 28th October 2007, 03:33 PM   #5
Pabo is offline Pabo  Sweden
Eva
"Ok, I give up..."
That was funny
Tekko
Your IC2 will probably have enough phase lag to cause self oscillation but it will be grossly non linear as it will be working in slew limiting mode all the time. I suggest that you add poles to IC2 and choose a model with high bandwidth for example AD8512.
I do not think that the driver will work well with one input low all the time? How where you thinking there?
Instead put a comparator after the OPAMP with dual outputs (one inverting).
You also need dual supplies for the OPAMPs (+/-12V).
If something that measures good doesnīt sound good, measure again!
Old 28th October 2007, 03:52 PM   #6
Banned
The input on a HIP4080 actually is a comparator.
I have seen schemes with poles on th feedback, add second set of resistors and place caps to ground, but iīm not sure if theres any benefit or any difference in doing that.
There is also LT1220, but all i have available at this time is TL082 and LF356.
Old 28th October 2007, 04:11 PM   #7
Banned
So heres one with dual output comparator before HIP4080:
schemo
I canīt find the AD suggested in eagle.
Old 29th October 2007, 01:23 PM   #8
Banned
Iīm not trying out this thing on a breadboard.
Iīll let you know how it goes.
Old 29th October 2007, 08:33 PM   #9
Banned
It dident work, the HIP4080 get hotter than hell.
Old 30th October 2007, 10:49 AM   #10
Whortless is offline Whortless  Turkey
Whortless's Avatar
Tekko,
Put a reference on + input of the 4080 (12V/2=6V). So you do not need symetrical opamp supply( do not left +in of the comparator floating). Pay attention to voltage on Vdd/Vcc pin of 4080, it should not exceed 15V. TL082/072 can work here but AD8512 is better.
full bridge selfosc class d ampHide this!Advertise here!
Common choke in full bridge class D lumanauw Class D 8 12th May 2008 07:50 AM
Feedback in a class d full bridge dcmdcm Class D 3 2nd June 2007 06:20 PM
Full Bridge Class D mcintoda Class D 8 8th January 2007 08:25 PM
