p-channel fets
p-channel fets
Old 26th October 2007, 03:24 PM   #1
Tekko is offline Tekko
Banned
Default p-channel fets
How would an output stage made with p-channel together with n-channel fets work massive shoot through ?
I bought same quantity of IRF9540 as i did of IRF540 just to try this.
Old 26th October 2007, 07:26 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Shoot through largely depends on the timing of the control signals regardless of what type of fets are used for the output stage.
Brian
Old 28th October 2007, 07:29 AM   #3
djk is offline djk
djk's Avatar
Think about this:
Shoot-through happens when the positive rail FET should be turned off and the negative rail FET is turned on before the gate charge is sucked out of the positive rail FET.
Linear Technology has an app note that compares the decaying voltage from the gate charge of the FET turning off and inhibits the other FET from turning on until the first gate drops below conduction threshold (about 2V).
What if your modulator circuit could swing 10V? You could tie the gates of an N-channel FET and a P-channel FET together. The voltage driving the P-channel FET could not rise enough to turn on until the gate charge on the N-channel device dropped below it's conduction threshold.
No shoot through!
How could we swing any real voltage into the load with only 10V on the gates?
Ground the sources of the FETs and hook the speaker hot to the transformer center tap.
A good opamp with a pair of class B followers would have enough muscle to drive the gate capacitance at high frequencies.
Fairchild has a nice 200V P-channel FET with only 0.17 ohm RDSon, or the IRF parts would work with rail voltages below 50V
Candidates for the Darwin Award should not read this author.
Old 29th October 2007, 12:22 PM   #4
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Hi djk, the concept is workable but will result in the PSU having to pass all the switching frequency through it.
I've attached a drawing of a TINA spice simulation I did of a version where the inductor is moved to between the PSU and the FETs, but needs to be wound bifilar. A large value capacitor ac-couples the drains of the FETs.
p-channel fetsHide this!Advertise here!
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 08:29 AM
Matched Fets Bigred Parts 0 18th February 2008 09:05 AM
How do n- and p-channel fets cancel distortion? jwb Solid State 2 1st December 2004 09:05 PM
Power N channel FETS quasi Swap Meet 0 11th November 2004 11:16 AM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 07:41 AM
Copyright ©1999-2017 diyAudio
