Go Back   Home > Forums > Amplifiers > Class D
Old 20th October 2011, 02:47 PM   #21
acid_k2 is offline acid_k2  Italy
Originally Posted by stewin View Post
i was wondering how can i adjust the switching frequency in this schematic?
UCD amps are self-oscillating, and the oscillator frequency is not fixed nor stable.
It depends on:
- output LC low-pass filter (L1 and C31 in the schematic you posted): this filter has a cut-off frequency at about 30-35 kHz for a full-range amp, it can be a lower for subwoofer amps.
- feedback RC network (C4, R11, R12) that causes the 180° phase shift needed to keep the oscillator running
and other less important things:
- inductance/load of the connected speaker
- power at the output
- PCB layout
- MOSfets commutation delay
- etc.
For further informations: UcD
As a rule, the feedback RC network keeps the oscillator frequency at about 10 times the cut-off frequency of the output filter, or more, so you can obtain a strong attenuation of the switching frequency on the speaker. A typical UCD amp's oscillator runs from 200kHz to 700kHz, or more.
Slowering frequency too much is generally non a good idea, you have to keep it as high as you can (as high as your UCD amp is running safe and stable), depending on the devices used in the circuit.
Old 21st October 2011, 03:25 PM   #22
stewin is offline stewin  Kenya
Thanks acid it is hard for me to understand the equations and terminologies but i will try to do my homework . just wondering in your schematic why you decided to use one rail vltg and why not use high vltg like +/-80vlts . and can you make a classd amp without the filter cap?
Old 21st October 2011, 03:58 PM   #23
Send a message via Yahoo to Th3 uN1Qu3
He used single rail because that's what he had lying around. That's why he had to use an output capacitor. Normally you would use a split supply so you can do without that capacitor.
Class D without output LC filter is possible, but NOT UcD which relies on the phase shift of the output filter to keep oscillating. And it is only possible at very low power, <10W, so that the amp doesn't put out significant amounts of radio interference. Speaker lead length must also be kept to a minimum, hence this approach is only used for cellphones, laptops, USB powered speakers and the like.
"Audio grade" components simply means that they failed at a more critical job.
Old 21st October 2011, 05:00 PM   #24
elevator's Avatar
Default Class D without output LC filter
[QUOTE=Th3 uN1Qu3;2753829]
Class D without output LC filter is possible, but NOT UcD which relies on the phase shift of the output filter to keep oscillating. /QUOTE]
Well that's not entirely true, you can create the phase shift separately. The UcD amp I'm building has the two options of feedback from before or after the output LC filter. The design (schematic attached) is based on the Silabs reference design (which only uses pre-filter feedback). Mine is not working yet, admitted, but it will be interesting to compare the two FB methods.
Old 24th October 2011, 05:13 PM   #25
I'm not sure a pre-filter feedback is a good idea. Anyway, elevator, you wrote that your amp is not working, what's wrong? Have you tried the classic post-filter FB?
Old 24th October 2011, 06:53 PM   #26
elevator's Avatar
Originally Posted by acid_k2 View Post
...elevator, you wrote that your amp is not working, what's wrong?
I'm still building it, that's what's wrong... Non voglio vendere la pelle dell'orso.
I'm not sure a pre-filter feedback is a good idea. [...] Have you tried the classic post-filter FB?
Well, if you read my post again, I did not say it was a good idea. I just said it is possible, contrary to what Th3 uN1Qu3 affirms. Also, I said that in my amp I am implementing both pre- and post (selectable), for A-B comparisons and tweakings
E
Old 25th October 2011, 10:42 AM   #27
Perhaps i didn't make myself clear enough - pre filter feedback IS possible but then it's not UcD. The UcD patent and original appnote are describing a self-oscillating amplifier with post filter feedback.
Old 25th October 2011, 11:28 AM   #28
elevator's Avatar
Ok got it. Now would that mean that pre-filter FB does not infringe on the Hypex IP? Sweet...
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 25th October 2011, 11:32 AM   #29
AFAIK no, it doesn't.
Old 30th March 2012, 10:40 PM   #30
hi acid k2 the continuation of my project
diysmps
JYD (junk yard dog) cnctooltek Multi-Way 10 18th October 2006 03:50 PM
New Chip Junk classd4sure Class D 85 20th September 2006 08:24 PM
Tip for Junk box Zen PSU? SM7UYJ Pass Labs 2 4th April 2005 09:57 PM
Just got new junk from my friend Giaime Solid State 29 22nd March 2005 12:29 PM
got some interesting junk yosh Parts 2 27th June 2004 09:01 AM
Page generated in 0.12501 seconds (77.98% PHP - 22.02% MySQL) with 11 queries
