Go Back   Home > Forums > Amplifiers > Class D
Old 2nd December 2007, 11:54 AM   #41
So what about this one ?
http://diymania.hv4all.com/selfosc%2...scdampbrd3.png
Old 2nd December 2007, 12:49 PM   #42
Carrier resudials = speaker cable will become an antenna and spew emi/rfi all over the place.
Which of the board designs sucks the least ?
The order to boardhouse have to be sent before the end of the day.
Btw why do you think all my board layouts sucks ?
Old 2nd December 2007, 03:55 PM   #43
Eva, eat this: i replaced the 22ohm gate resistors with 100ohm resistors and now the fets are COLD!!!! No heating!
There ya go, my circuit is working properly, on a breadboard:s mash:
Btw i´ve ordered the real boards now.
Old 2nd December 2007, 07:11 PM   #44
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
- Power supply loops must be shorter.
- The ground plane has too many cuts in the power loop zone, where it shouldn't have any.
- Gate drive loops may be made longer without much problem.
- Wider PCB tracks are less inductive.
Look at the PCB and try to visualize the paths that cross-conduction (reverse recovery) spikes and inductor current follow when switching is taking place.
I use to feel like the small child in The Emperor's New Clothes tale
Old 2nd December 2007, 08:19 PM   #45
Well with the recommended clearance of 20mil, thats what happen to ground planes, and its too late now, the boards are ordered.
I´ve tried everything and its impossible to get the ps loops shorter. Note that i also have small caps right at the fets, not only the lytics.
Btw i dont think the ground plane is too cut up as you say, it doesent even have any connections with the power components, except the speaker output and the caps.
And where would you put all the components that are now around the fets if neither long traces or gp cuts are allowed ?
Frankly i feel like i should ask fumac instead since he dident like the way your board was laid out, and that you are the only person on this forum to discredit others board designs. I start to think its all jealousy because other´s boards are actually better.
Anyways heres a shot of the groundplane only: http://diymania.hv4all.com/selfosc%2...nd%20plane.png
Btw i have a pair of class d caramps and they dont even have a groundplane.
Old 2nd December 2007, 09:02 PM   #46
http://diymania.hv4all.com/selfosc%2...brdlasttry.png <-- lemme guess, worst this far.
Old 2nd December 2007, 09:14 PM   #47
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Tekko, if you don't want to heed advice that you asked for then don't. Simple as that. You're obviously free to build your amp as you see fit.
Brian
Old 2nd December 2007, 11:31 PM   #48
Eva's Avatar
You are still not figuring out all the high current high frequency paths.
Most of the switching RF current will try to flow from one supply rail to another through the small ceramic decoupling capacitors. Note that the ground plane is in the way from one capacitor to another... Gate drive current will also flow through the MOSFETs to the supply rails and then to the ground plane through the ceramic caps, then it will flow to the ground pin of the gate driver and to its +Vcc pin through the corresponding supply capacitor. Switching current in the lower RF range will flow through the main electrolytics.
You need to set up a little PSpice circuit simulation engine in your brain in order to produce good layouts
Old 3rd December 2007, 03:06 PM   #49
This project started as a simulation.
Old 3rd December 2007, 06:51 PM   #50
http://diymania.hv4all.com/selfosc%2...rdlasttry1.png <-- worst/crappiest one this far eh ?
new FR 8's Wild Burro Audio Labs freddi Full Range 99 13th July 2009 01:52 AM
Cal Audio Labs CL-15 bungelow_ed Digital Source 0 8th July 2009 02:21 PM
Invisible Audio Solutions from Emo Labs angeloitacare Multi-Way 2 23rd January 2009 06:18 PM
Another California Audio Labs CL-5 Question neddyboy Digital Source 1 7th October 2007 11:06 AM
Agape Audio Labs Hagto Tubes / Valves 0 5th May 2006 05:45 PM
Page generated in 0.10444 seconds (82.86% PHP - 17.14% MySQL) with 10 queries
