| Class D Switching Power Amplifiers and Power D/A conversion |
Hi !!
I bought from Digikey, 6 TDA8920BJ IC's. It needs a 22uH + 680nF output filter to work with 4Ohms load, and 47uH + 330nF to work with 8 Ohms. Question... Why does it need different output filters to work with different loads? It isn't just a low pass filter to take PWM signal away from the speaker Well ! I REALLY want to hear this little thing, It's my first D amp, and I'm quite excited ! I can't get inductor easily around here, so I want to build my own. I have here on the shelf a enlammed copper wire 18AWG, and a bunch of old computer PSUs. Can I make my inductor from this? What about an aircore inductor, does it sounds better ? I also can buy ferrite core, and wind in myself, and of course, to buy it I must know the size that I don't have any idea yet ! Thank you so much !!!!! Best Regards ! |
#2 |
For Tube style airCore, I remember...
L [nH] = ( Turns x TubeDiaMeter[mm] )^2 / Length[mm] example, (200 turns x 5mm diameter)^2 / 10mm length = 100uH anyway very large but no core distortion. (sorry first equation had mistake) |
#3 |
Very VERY large you mean ! For 47uH it would need > 2000 turns
I need calculate it for ferrite core ! This would work fine for me: http://uk.farnell.com/jsp/Passive+Co...sp?sku=1077056 BUT... I live in brazil, the land of corruption, and this sh**T costs 26 reais, 13usd... Ridiculous for a simple inductor, and I need two for each amp. !
#4 |
I found a Store that have everything to make inductors, many types of ferrite, and all sizes of copper wire.
I need some technical information before go there and buy these components. Which ferrite former is better? The amp works with +/- 27v, and is 2 Ohms compatible. What is the recommended current rating for the inductor ? Thank you very much ! |
#5 |
First attempt ! How does it look like? Is it good?
Hehehehehe just a joke ! Apart of this, I really need help regarding this !!!
#6 |
Sorry I can't answer your questions, but here is a very handy calculator for ferrite and iron powder cores.......
http://www.66pacific.com/calculators/toroid_calc.aspx
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#7 |
I couldn't wait for an answer, and I went to the store and bought some ferrite cores. They were VERY cheap. I just finishied winding it right now, and here is the picture of the inductor.
The wire is 18AWG, 28 turns, how much uH do you guys think that it have? Thank you ! |
#8 | |
If these are ferrite toroids (0.9 inches?) you get 1000uH (1mH) with material 68, that has low permeability (20) and about 35mH (35000uH) if material type is 43 (850 perm)..... I don't think this is the right material for the application. Take T106 Iron Powder cores with low perm. The red type (perm 10) needs 59 turns of wire to get 47uH. If you use 20AWG the turns will fit in a single layer. |
#9 |
I also have two ferrite cores, one is type 62 and other is 49. The Type 62 is bigger, and have a hole diameter of 15mm and 5mm of lenght.
The type 49 have a hole diameter of 13mm and 10mm of lenght. I'm not sure about the ferrite types, so I took a picture of it, as it was difficult to read I wrote using mspaint what is marked on it. Take a look: |
#10 |
the other
| Copper coil inductor vs. round core inductor | tomchaoda | Pass Labs | 7 | 21st September 2011 04:42 AM |
| air core inductor vs. iron core inductor | WBS | Planars & Exotics | 5 | 7th May 2007 11:02 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| PLEASE help me build an inductor | guitar333 | Multi-Way | 4 | 2nd July 2003 02:28 PM |
| Page generated in 0.12092 seconds (73.89% PHP - 26.11% MySQL) with 11 queries |
