Go Back   Home > Forums > Amplifiers > Class D
Old 26th September 2007, 06:19 PM   #1
Default Power for 3 Trends Amps
I'm thinking of putting my three Trends amps into a single case. Will this power supply work if I use a single power connection for tthe amps?
AC/DC Power Supply - 12VDC, 12.5A, 150W
Short-circuit / over-load / over-voltage protection
DC output adjustable to +/- 10% of rated output voltage
AC Input: 88-132VAC / 176-264VAC selectable by switch
Approvals: UL cUL TUV CE CB
199x110x50mm
Two Year warranty
Old 26th September 2007, 08:37 PM   #2
Pano is offline Pano  United States
Pano's Avatar
That's a big supply, don't think you'll have any trouble with it powering 3 T- amps. As I figure it, you would draw maximum 11A running all six channels full power sine wave into 4 ohms. Average musical draw will be much, much less. Maybe 1A.
You might be able to dial up the voltage a bit, to about 13 volts. That will give you a little more headroom - and you'll need all you can get.
You won't know until you try it, so YMMV. Does it say that it needs a minimum current draw?
Take the Speaker Voltage Test!
Old 26th September 2007, 09:12 PM   #3
Thanks Pono, I figure if anyone would know, it would be you.
This is my second option, but it only comes in 8 amps
AC/DC Power Supply - 13.5VDC, 8A, 120W
Input Voltage: 88-132 or 176-264VAC
Output Voltage: 13.5VDC @ 8A
AC input range selectable by switch
Protections: short circuit / over load / over voltage / over temp.
3 color LED loading indicator
Cooling by free air convection
Fixed switching frequency at 25kHz
Approvals: CSA / NRTLC / CE
Two year warranty
Old 26th September 2007, 11:12 PM   #4
Pano's Avatar
You're welcome!
The second one says it has a switching frequency of 25Khz. Getting kinda close to the audio spectrum, there.
No telling form the specs how well either is filtered. You can add some filtering if you need to.
Old 27th September 2007, 12:01 AM   #5
What will be involved in making a filter?
trends TA-10 ideal power requirements jeremyrosehifi Class D 4 29th April 2009 03:03 PM
SLA battery power for Trends TA10.1 aquapiranha Class D 4 4th March 2008 09:24 PM
Trends TA-10 Power Nappyhead Class D 5 29th November 2007 02:55 AM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
Page generated in 0.07973 seconds (75.84% PHP - 24.16% MySQL) with 11 queries
