diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Discrete input modulator (http://www.diyaudio.com/forums/class-d/109099-discrete-input-modulator.html)
Whortless 26th September 2007 05:26 PM
2 Attachment(s)
Hi to all,
Since my last project streo class-d amp with HIP4081 I am trying to implement a good input section to improve sound quality. Althoug my amp is good on sound scope results tell me some improvments.
Any way I tried a discrete input comparator section of UCD amp. This comparator eliminates input opamp/integrator. Probably it is very usefull for full bridge desing but, for an half bridge one have to implement a FB network to it.
You all experienced DIY'ers on Class-D "Baldin,,Fumac, RX5, Luka, BWRX and others" please tell me how can I implemet the FB network to this input?
All comments are will be helpfull.
File enclosed on SWcadIII
Best Regards
BWRX 26th September 2007 06:11 PM
Try modeling the HIP4081 as a transmission line with propagation delay (~50ns typical or ~100ns max according to the HIP4081 datasheet) and the mosfets as current or voltage controlled switches. Add the LC output filter and feedback loop and you can start experimenting with component values. Look at the diagram in the first post of the "Philips UCD application note" to see the feedback network and some component values that will help get you started.
Whortless 26th September 2007 08:23 PM
2 Attachment(s)
Thanks BWRX,
I enclosed a signal result. This input section is not only for HIP4081 but also IR2113( R1 still adjusting the dead time). Power supply lines can go up to +/-50 or +/-60V for a high power full range amp. I do not thinking about a IC version of UCD. As you can see it has a triangle wave input. Therefore it is not self osc. type. Inverting input of this comp will get overal audio signal and FB. Question is that, should I use the FB network after the filter inductor?
Whortless 27th September 2007 06:02 PM
2 Attachment(s)
Ok , Ok I see and the answer resulted itself by reading Bruno Putzeys' AES paper. I understand that , Hysterisis mode swiching can be achieved before the filter inductor and UCD mode is more audible than hysterisis mode. OK, see the enclosed IC version of UCD . It is based on a slow mosfet driver LT1160.
I will try this input modulator with IR2113. The resistor (R1) adjusts the dead time but this time decreasing its value inreases the dead time.
Ok, What can be the advantage of this circuit and what do you think is it valuable to create so kind of an amp?
Whortless 28th September 2007 06:38 PM
Hi, As I see, i am discussing something myself :( . I introduce the discrete modulator to IR2113 and HIP 4081. While IR2113 is modulating at 280Khz , HIP modulates at 109Khz with 100K Del. resistors(probably decrasing del resistors would give higher oscillating f). But, the strange thing not heat on mosfets with both IC drived UCD. I played with dead time resistor R1 and increased it to 1K. On lower values of R1 (330,390,470,510,680) there is a bit more distorted sound because of higly increased dead time. This is the IC promoted UCD :). I think this is a good experimentig circuit and DIY'ers can love it.
If someone will not give reply, moderators should delete this thread.
BWRX 28th September 2007 09:37 PM
Hi Whortless. Please don't get discouraged if you don't get many replies. You're working on something that not a lot of people understand very well - I'll freely admit I fall into that group!
I don't have my windows computer anymore, so I can't open the asc file. Any chance you could post a GIF image of the SwCAD schematic?
Experimenting is one of the best ways to learn how part changes affect circuit operation. You've read some good documents all ready. There's also a good thread by SSassen about designing/building a non-discrete UcD amp. Might be worth having a read through it: http://www.diyaudio.com/forums/showt...threadid=58476
Whortless 29th September 2007 12:12 PM
2 Attachment(s)
Hi, BWRX
Thanks for the reply. I enclosed the lastes shematic version in GIF format. In my view the advantage of using a mosfet driver is not to striving with component values of two PNP transistors in UCD.
Now, let us to try the increasing the sw frequency for better sound quality.
Whortless 29th September 2007 06:49 PM
Hi All,
Try this on last shematic ; R1=680, R11=33K, C8= 470p and R12,R6,R5+ C10,C5,C2=open. Get the FB before the filter inductor. What the swiching topology is now?
Driver IR2113 and I get 500Khz without heat. Tomorrow I will show the scop results if I could get. Hıım , Do not forget to apply audio signal otherwise will not oscillate.
Whortless 2nd October 2007 07:23 PM
Here one of the scop picture
2 Attachment(s)
Here one of the scop picture. It is running with IR2113+IRF540N 22R gate and 680R dead time resistors. Last version used (hyteresis mode?) integretor cap 1nf, FB 33K.
I know it is not quite to show all the results. But sound is better than my HIP4081 delta-sigma modulated amplifier in my room. Also the amp is runnig on bread board, therefore a good desined PCB can give a better result( I measured 20.42V RMS on 4ohm speaker with +/-35V split supply before the distorsion). SW frequency is adjustible by changing the integrator cap's (C8) value, 500Khz is an obtainable one but 260Khz is moderate and audible.
Waiting for the comments
luka 8th October 2007 08:02 PM
Hi
First of all I must say nice job, looks great. If you ask me sigma-delta modulation is the best, in audio sense too, at least for me...
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
