Errr, I searched but didn't find anything. But then, my searches on DIYAudio frequently don't turn up what I was expecting.
So can it be that nobody has talked about the Sonic Impact T-Amp Gen 2?
$60 at Parts Express, looks prettied up from the first one, includes PS (3 A). Anyone heard it? Anyone looked inside yet? What is the same, what's different? Input caps, PS cap, potentiometer?
http://www.si5.com/products.php?pID=4046
theAnonymous1 said:Wow, $30 worth of extra plastic!!!!
I say buy the original and use the extra money on a nicer case.
I should have expected that! If that is the plan, go right to a kit.
Do you figure the changes are only cosmetic? I would hope they improved the LF response the the hookups.
Gio
Getting a nice case can be pretty expensive...
I think it was the PE page that mentions it is redesigned from the ground up. So who knows, it might be different inside. If nothing else I would hope to see larger input caps, if maybe not higher quality ones...
From the pics it looks like the speaker outs are still the cheapo clamps, and the line in is still a headphone plug.
Here's the PE page: http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-958
I can't imagine there is anything revolutionary inside. They could have at least put some cheap binding posts and RCA jacks on the back.
Says who? I think this is much nicer than a plastic clam shell and it's anything but expensive........
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=262-074
AdamThorne said:Getting a nice case can be pretty expensive...
I find it very funny how SI used the heading "Pro Amplifiers" on their website.
It's also worth noting that they have reduced the listed output power of the standard SI and the Gen 2 to 5W per channel while leaving the Super-T's listing at 15W per channel... What a marketing ploy.
BWRX said:I find it very funny how SI used the heading "Pro Amplifiers" on their website.
Yes the "M" word. IMHO that's all this new amp is.
I think Sonic Impact hit on something they weren't quite expecting with the original amp and now they are trying to ride the "T-Amp" horse until it has split hooves and broken legs.
Anon1
Your case looks killer! Did you... what, paint it? Bronze it? Something? Yours looks bronze, but the PE part you linked looks black.
Marketing ploy? Maybe just capitalism in action. Quality amp, great price but never in stock? The obvious answer is raise the price. If SF increases it's margins maybe they'll be able to manufacture them fast enough that you can buy one w/o a 2 month wait...
AdamThorne said:Anon1
The ends are scrap pieces of copper I had. I would have been fine using the stock end plates and some hammer finish, but I had the copper already and I thought it would look better.
AdamThorne said:Marketing ploy? Maybe just capitalism in action. Quality amp, great price but never in stock? The obvious answer is raise the price.
All three amps SI offers (T-amp, Gen 2, and Super-T) use the same Tripath chip and basically the same circuit and components. I'll bet the Gen 2 is just a slightly revised T-amp (probably just a few component upgrades) in a new case with a higher price.
theAnonymous1 said:
your amp looks great. where did u get the knob?
panomaniac said:Well I'll know soon. Have one on the way.
Won't be able to do any modding until after RMAF, but I'll post what info I find - along with pix.
always look forward your input and pictures so newbies like me can follow.
gychang
gychang said:your amp looks great. where did u get the knob?
They bought them off ebay.....
http://cgi.ebay.com/3-40X19-Aluminu...ryZ58163QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They are for spline shafts though. I didn't realize this when I bought them and had to modify them a bit to fit a D shaft. It was a PITA so I don't recommend trying it.
First Look at GEN-2
Got one today. Nice little box. About the same size as the original Sonic. Still all plastic, but not nearly as tall. Thinner and deeper.
And it comes with a power supply! Ah, ha. That's where the higher price come in. Same style of 12V SMPS as comes with The Super-T or the Trends.
New amp has the same cheap little spring clips on the back for the speakers. Not the worlds best, but meant for a small portable amp like this. Good binding posts might weigh more than the whole amp.
Same 1/8" mini plug for audio input. Battery compartments on the sides underneath, just like the first one. 8 AA batteries.
Here's an odd thing, it has a headphone jack! I don't know yet how it's fed, it may simply jump off the input.
You can see the photo below with an old SI case on top for comparison.
The Insides
What's inside?
Have a look at the photo below.
All new printed circuit board. New pot and switch. Cool blue LEDs for the volume knob.
On the right you'll see the wires leading to headphone jack.
There are 3 transistors on the PCB, don't know yet what they do, maybe power-on pop suppression.
Seems to be the same output section as the Sonic Gen-1. There is a 470uF cap on the PCB near pin 1 (lower left of photo). Might be the power cap AKA "tank cap."
I'll check into all this when I get a chance. Just thought y'all would like to see the new beast.
What's inside?
- Class D
- Sonic Impact Gen 2 T-Amp ?
