| Class D Switching Power Amplifiers and Power D/A conversion |
Short Version:
I am using a full bridge design, and I have PWM signals coming from my output NMOS to the inductors. Before the inductor, it is a 0-20V PWM signal... after the inductors, it is a 5-20V mostly-sine wave. The resulting differential signal across the 8 ohm resistor has Vpp of 27V-- resulting in 11.7W. I need 25W to get a B. That means I need the Vpp to be closer to 40. How can I get less voltage drop across this inductor? (Inductor value: 220 uH. Capacitor value: 4uF. Set up in typical L-R-L -C- arrangement with capacitors to ground as well.) Long version: Hello all-- First I would like to apologize for the rushed nature of this post. I was trying to design the entire thing on my own, but I have run into a problem that I can't solve, so I would like to get a B instead of a D. Background: I started this project with a partner, we were to build the entire amplifier over the summer. It was my partners idea, so I was basically letting him set the pace. Bad idea-- he got kicked out of my major with a GPA below 2.0, and I was left to finish his half of the project. I have built a working Class D amplifier, full bridge, using a triangle wave and a comparator, but the output is nothing to be proud of. That was his half of the project, so I am learning it on the fly. In order to get a B, I need 25W. I was able to get 11.7W today, but I would like any sort of expert advice on how to improve it. Output: For now, I think it is safe to ignore all of the circuitry before the Gate drivers. It is a basic Preamp design, with a triangle wave and a comparator, and it works within the range I need it to. The gate drivers are Fairchild 73832 parts. I have a .22 uF capacitor acting as the boostrap capacitor to drive the high side NMOS. The NMOS are Fairchild FDB8447 parts. If you haven't noticed, I get free Fairchild stuff ![]() I have the Gate Driver running on a 15V supply, while the NMOS power supply goes from 20V to 0V. I can increase or decrease this within any reasonable limit. Output Filter: I had to scurry about and make the full bridge design work, so I didn't plan things out as well as I would typically like. I took the basic design that I have seen for this sort of load-- inductors in series with the load, with a capacitor in parallel, and two capacitors to ground. I only need the low pass filter to pass 10Hz-2kHz input, so I think my values are appropriate. Doubling the 4uF and halfing the 8 ohm load gives a basic LC filter with 220uH, 8 uF and 4 ohm load. The cutoff frequency should be somewhere around 4kHz. If anyone wants more information, I can gladly fill in the rest of the circuit-- I am a bit ashamed of it, as it is very crude and basic, but as I said-- I had to just throw things together a bit. Any advice on any part of this output stage would be awesome. Thank you very much! |
#2 |
#3 |
What's your switching frequency and your signal frequency?
#4 |
Switching at only 20kHz, as my input has to be between 10Hz and 2 kHz.
I can change the switching frequency up to 1 MHz with the chip I am using, but I would only do that to get full audio, which I don't need for B grade. |
#5 |
diyAudio Moderator Emeritus
Try increasing the switching frequency to say 100kHz and raising the cutoff frequency of the output filter (so you can use smaller inductors and caps).
A good rule of thumb is to a use a switching frequency that is at least 10x the highest frequency you want to reproduce.
Brian |
#6 |
At what point will the increase in the switching frequency start causing trouble?
I can change the switching frequency basically at will-- just slap a new cap in there and it works. But the cutoff filter is the hard part, I have to order new parts if I want to change that. And I only have a week. I think I will try pumping the switching frequency to about 40kHz, so 20X... and leaving the filter. (FYI, I put a .47 uF cap in the filter, instead of the 4, and it changed the output but did not increase the power... so I can't increase the power by moving the cutoff frequency unless I order a new inductor, I guess) Any more advice? Thanks for the feedback, I really appreciate it-- I forgot completely about the switching frequency, and there are probably more things you guys can point out. |
#7 |
And I phrased it wrong, but I meant that as in I will test it tomorrow, at 40kHz and with the same components, because I would have to order new ones.
If that doesn't help, I'll order some new inductors and maybe go for full audio band. |
#8 |
If you are using toroidal inductors you can just unwind some turns to lower the inductance.
Higher switching frequencies require better PCB layout and closer consideration of parasitics. The 300-400kHz is a good range to aim for as far as class d audio amps are concerned (that's just my opinion). Higher is better, of course, because it shifts the switching frequency further away from the audio band and allows the use of a higher cutoff frequency (smaller inductors, capacitors).
Brian |
#9 |
Yeah, this project is completely not up to my standards of work. I was told that we didn't have to do the PCB design until fall semester, so the project that I have now is just on circuit board.
There are inches of wires connecting the inductor to the resistor, and unfortunately, there is little I can do about it. Thats one reason I am trying to lessen the switching frequency for now. Turns out the entire project needs to be built by now, but I think I will design it in PCB just for prides sake, even though it won't help my grade. |
#10 |
| Amplifier question - Apex Senior versus PE Dayton | OHjim | Subwoofers | 0 | 22nd July 2008 02:46 AM |
| Senior design help | matpac1 | Parts | 0 | 7th October 2007 11:49 PM |
| Completed senior design Class D | boss_dj24 | Class D | 2 | 30th May 2007 04:58 AM |
| Senior Design Newbie | Deltat | Introductions | 8 | 1st May 2005 12:56 AM |
| My senior Design Project | Deltat | Chip Amps | 17 | 26th April 2005 07:53 PM |
| Page generated in 0.12668 seconds (76.58% PHP - 23.42% MySQL) with 10 queries |
