Go Back   Home > Forums > Amplifiers > Class D
Old 20th September 2007, 06:16 AM   #1
Post Sonic Impact balance problem?
Hi - I've been lurking around but into audio for a while. Anyway, my class a/b generic amp started blaring out square waves and so while I RMA it I figured I'd check out a SI T amp since I've heard a lot about them for a while... I'm pushing a pair of Audio Nirvana Super 10's with it, so the low power output is fine. Anyway, at low volumes, only the left channel comes on... then at minor volumes, the right starts to come in, but it always seems to lag about 5-6dB behind the left. Has anyone else had this problem? How can I fix it? Are the batteries I put in on the right side weaker?
Old 20th September 2007, 11:16 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Sounds like a problem with the volume pot.
Just how good a pot did you want in a $30 amp?
Only way to fix it is to replace it. But hey, you wanted to mod and upgrade anyway, right?
Take the Speaker Voltage Test!
Old 20th September 2007, 04:43 PM   #3
Well - My other thought was maybe I could just eliminate the volume pot altogether...
Old 20th September 2007, 08:18 PM   #4
Pano's Avatar
That would be a good idea, if you have a preamp. No need for 2 volume controls.
Do you run yours with a preamp?
Old 21st September 2007, 01:59 AM   #5
ahh no - but i'm feeding it an input signal from my computer... I know it's not the best but I can adjust volume with the computer, no?
Old 21st September 2007, 02:03 AM   #6
gychang is offline gychang  United States
Default Re: Sonic Impact balance problem?
Originally posted by nukegoat
Hi - Anyway, at low volumes, only the left channel comes on... then at minor volumes, the right starts to come in, but it always seems to lag about 5-6dB behind the left. Has anyone else had this problem? How can I fix it? Are the batteries I put in on the right side weaker?
I had the same problem and sent it back for replacement. Guess this is why so cheap, since than I messed it up trying to mod. Long story...
gychang
Old 21st September 2007, 03:07 AM   #7
eclectic2k's Avatar
nukegoat,
yes, you could control volume with the PC with no problems I'd say - however, it's possible that might be as bad for sound quality as the cheap volume pot (though much better for balance I'm sure)
just be careful when you power everything up where that software volume is set!
I recently ran across a short basic comparison of operating system volume controls here:
http://www.benchmarkmedia.com/comput...usb_audio.html
but then there are a huge number of variables in the PC world anyway, so depending on your audio card/ouput your software etc... this may be better or worse - so try it and find out! - heck running through the T-amp, it can't be that big of a deal ;-)
Old 21st September 2007, 05:06 PM   #8
I think my ears are more sensitive to peaks and dips in frequency response than they are 110 vs 120 s/n ratios. People talk about the virtues of the t-amp over standard class a/b as if it's night and day... to me it's inframarginal, I can't even hear the difference... I wonder if I'll get banned on this board for saying that, though...
Thanks guys
Old 21st September 2007, 05:26 PM   #9
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
You are being deleted as I type...
Brian
Old 21st September 2007, 07:45 PM   #10
haha... it's not to say I won't continue buying the film and foil caps, refusing to use anything other than 12awg wire and being picky about the quality of interconnects - i just know that technically someone could switch most of those things without me knowing and I'd never figure it out. I guess years of SPL competition ruined me
Sonic impact t-amp problem/question. doogyscoot Class D 2 6th August 2008 03:05 PM
Sonic impact T-amp gen2 problem andywhale Class D 1 21st April 2008 11:54 AM
Sonic Impact Problem ronniea Class D 2 15th August 2006 11:35 AM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
Sonic Impact Bizarre Problem HolyGhostFire20 Class D 4 14th December 2005 02:33 AM
Page generated in 0.12231 seconds (74.90% PHP - 25.10% MySQL) with 10 queries
