Trends Audio TA-10 - right channel crackles. It's rare, but annoying. - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd October 2007, 08:03 AM   #11
Pano is offline Pano  United States
Pano's Avatar
Default Re: Re: It's not the TA-10!
Originally posted by rbclark
The "direct" mode is flat.
I suppose you do not mean flat as in a flat frequency response - you mean "lacking depth."
Your preamp is probably pumping up the lows and low mids -maybe the top end, too. That would tend to give the sound more "body", something sorely needed by most fullrange drivers. If you are using the mic and auto EQ, then the preamp may be adjusting for the missing bass that so many FR drivers have. In other words, the auto EQ in the Pioneer is making up for the lack of bass and low mid provided by your speaker/room combo.
Yeah, it's better to avoid as much processing as you can, but if this EQ is happening fully in the digital domain it may be fairly benign. The best sounding solution is usually to have a speaker that can faithfully reproduce most of the frequency range. Those are either very large, or need lots of power. A 6" driver is going to be hard pressed to provide much low end, especially a full range 6". It's going to need a lot of help from the cabinet.
So you may be boosting the bass and low mids that are typically weak with FR speakers. If it works, why worry? The only big problem I foresee is the Trends running out of power with all the EQ bass boost.
I suggest you play around with the DSP settings on the Pioneer, find what you like. The automated room correction would be a good place to start. It will should) correct the frequency response of your Fostex speakers.
Later on you may want a "bigger, better" speaker that does not need so much EQ to sound tonally balanced.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 3rd October 2007, 09:45 AM   #12
rbclark is offline rbclark  United States
Default Re: Re: Re: It's not the TA-10!
Thanks for the discussion on this. Yes - lacking depth. I'll definitely be doing some experimentation with the preamp settings.
I have two other speaker enhancements on my todo list: 1 - I may build the Spawn Iris ; 2 - I have a sub woofer I intend to try out. But for now, with what the pre-amp is doing, I'm pretty happy - except for the occasional crackle in the right channel.
Thanks,
Bob
Two identical Trends TA10.1, left channel of one hisses. OzMikeH Class D 7 16th May 2008 10:18 AM
Trends Audio TA-10 Questions echomancer Class D 7 24th December 2007 01:53 AM
FT: Trends Audio TA-10 marginwalker Swap Meet 9 8th August 2007 05:04 PM
Trends Audio DAC Supply ecodoppler Digital Source 0 2nd July 2007 04:52 PM
SB3 as Preamp with Trends Audio 10.1 Shiznit Digital Source 0 20th May 2007 07:29 PM
Copyright 1999-2017 diyAudio
