| Class D Switching Power Amplifiers and Power D/A conversion |
I bought 3 of these: http://www.bgmicro.com/index.asp?Pag...D&ProdID=12293
I plugged them into one of my TA-10s. Immediately a high pitched whine came out. I tried all 3 of them on two different TA-10s. Same result. Be warned, YMMV. |
#2 |
Well that's bad news! Hope there was no damage.
I've bought a lot of power supplies from BG-Micro and never had a problem. Have even bought the Hi-Pro brand with no troubles. Are you able to check voltage and polarity? If they don't work, you should certainly send them back. Sorry to have misguided you.
Take the Speaker Voltage Test! |
#3 | |
gychang |
#4 |
I have this same SMPS and use it with a Charlize.Never had a problem.How close do you have the PS to the amp? Could it be a RF problem???
#5 |
www.halted.com had a few different power supplies that might work for you--can't guarantee quality though!
matt |
#6 |
Skynet USA is willing to sell single power supplies, and the prices are very reasonable.
http://www.skynetusa.com/ |
#7 | |
#8 |
Preiter-try putting an electrolytic cap(any size should do,the bigger the better) across the output of the supply.If it's the supply,that should fix the problem.
Sorry,I don't have any experience with the Trends amp,just the Charlize with this supply. Good luck,Steve
#9 | |
anyone else have the problem with TA-10? thanks, gychang |
#10 | |
I tried different AC outlets, moving the brick around while listening, and unplugging the stock TA-10 power supply. Nothing affected it. |
| Micro Jacks and Micro Pins for board-board connection | jazzist | Parts | 1 | 12th May 2008 03:02 PM |
| Just bought possibly the last amp I'll ever need! | ppia600 | Car Audio | 13 | 22nd January 2008 10:31 PM |
| Just bought a new guitar | pjpoes | Instruments and Amps | 5 | 14th November 2006 01:30 PM |
| Bought: Avalanche 18 | danvan | Subwoofers | 2 | 15th March 2005 06:24 AM |
| Page generated in 0.10615 seconds (78.32% PHP - 21.68% MySQL) with 10 queries |
