Go Back   Home > Forums > Amplifiers > Class D
Old 9th August 2007, 01:42 AM   #1
fredos is offline fredos  Canada
Default ''special'' mosfet driver...
Back again!
I need to drive a pair of (power!) P and N mosfet, source to ground, from LM319 comparator at + and - 10V. I already try 1.5K pull up resistor and a pair of PNP and NPN transistor as buffer, but near maximum duty cycle, this seem unsuficient...I try a TC4420 ( at 20V), this work very well, but its over the maximum rating of manufacturer....Anybody has already do some discret and SIMPLE driver that can provide + and minus 10 to 15V to drive mosfet?
Fredos
Yeah it's for a class d amplifier!
Old 9th August 2007, 02:49 AM   #2
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Fredos,
Did you tried using IRFD9110/110 complementary mosfets in Common source configuration to drive the large power mosfets!!!
Amazed to see a guy capable of designing KW level PWM amps is searching here on this forum for drivers..........
Kanwar
Old 9th August 2007, 01:45 PM   #3
alfsch is offline alfsch  Germany
hi fredos,
a year ago i had this in mind: (pic)
you think about something like this?
for small mosfet, as trans i tried: bc516/17 , 1A darling
for bigger gates, komp.fet driver: irf7389 , 30v, 30a peak
monster , fast driver: tc4422
Old 9th August 2007, 02:42 PM   #4
Thanks for reply...
alfsch
That's exactly the way I have try, but at 250Khz with a LM319, at maximum duty cycle, I can't drive correctly mosfet...It work very well with a TC4420, but I'm over maximum rating of IC....
Workhorse
I have already try the source follower, but with voltage drop I can't bring power mosfet in full saturation...I have try common drain configuration with reverse input on my comparator, but introduce too much delay in rise and fall time....I'm looking to design a class d with less than 100ns response time...just the LM319 introduce nearly 40 ns, TC4420 35 ns, and mosfet itself nearly 40 ns....So with TC4420 solution, I'm out of my spec...With a pair of PNP and NPN driving transistor, I can reach my goal...But prob at maximum duty cycle....
At least, I will simply limit duty cycle and raise PSU voltage to keep same power....
Fredos
Old 9th August 2007, 08:06 PM   #5
diyAudio Moderator Emeritus
Hi, Alfsch,
Interesting design ClassD version of Transnova. How to adjust the dead time in your design?
Old 9th August 2007, 08:06 PM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I don't understand how a direct coupled gate-drive circuit can exhibit duty-cycle-dependent performance.
I use to feel like the small child in The Emperor's New Clothes tale
Old 10th August 2007, 02:46 AM   #7
Workhorse's Avatar
But what exactly is the problem when driving with full duty cycle........
Old 10th August 2007, 06:06 AM   #8
mzzj is offline mzzj  Finland
Isn't LM319 a bit slow if you want less than 100ns total response time?
And please try to be more specific what is exactly your problem with high dyty cycles?
Old 10th August 2007, 11:15 AM   #9
#lumanauw: depending on gate-drive /resistors you get a slew rate , about 0,5v/ns at the gates; from +4 to -4 v , one fet closing, other gets on, about 16ns "dead-time" ; using res+diode at gates you can adjust the dead-time even more;
and fets switch off faster , because negative driven
next is, because there is some stray ind. between the windings of the fets, the shoot, if any, is much smaller...
the problem is, you need n + p fets, so its only for small amps, lets say max. +/- 40v, with 100v fets like irf540/9540
Old 10th August 2007, 11:48 AM   #10
Hi, Alfsch,
Nice Did you eventually built it? I noticed something. The feedback is taken after the LC filter. Is this UcD?
The parameter difference between Nch (IRF540) and Pch (IRF9640), will this be a problem in real cct?
Hi, Fredos,
Q4-Q5=common collector bipolars, driving Q2-Q3=common source mosfets, and the drains are driving Q1 (the big mosfet)
MOSFET Amp Modules on Special! The Saint Vendor's Bazaar 0 13th November 2008 05:48 AM
Mosfet driver IC's hairylee Class D 92 30th March 2008 04:22 AM
Mosfet audio driver mik Chip Amps 11 28th October 2003 04:14 PM
Page generated in 0.10425 seconds (81.32% PHP - 18.68% MySQL) with 11 queries
