Noob question about output MOSFETS
I was just wondering how the high power Tripath amps I have seen all use N-channel devices for both rails? Any class-a/b amp I have seen requires both N-channel and P-channel.:confused:
Re: Noob question about output MOSFETS
Take a look at the schematics here |
Do some research about quasi-complementary class-AB amplifiers ;)
Thanks, so this is called quasi-complementary.:o
So my next question; why did Tripath choose quasi-complementary? Is there a benefit other than only needing to stock N-channel devices? I assume N-channel gives more options with better specs too. |
In comparison with P-ch, N-ch MOSFETs feature much lower on-resistance (Rds-on) given the same amount of silicon and the same capacitances. Rds-on is not so important in class AB because output devices operate in the linear region, but in class D they are either fully turned on or fully turned off, so Rds-on is one of the key parameters that determine how hot the thing is going to operate... ;)
Thank you Eva, it all makes sense now.:D
| All times are GMT. The time now is 01:24 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
