Sonic Impact bi-amping - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd August 2007, 09:16 AM   #11
mustik is offline mustik  Finland
First, thank you all for your input. My first post about a problem that is quite trivial to you more advanced diyers produced soo many excellent replies already. I feel very welcome. Thank you!
So, at this point I will simply power my t-amps each with it's own Mascot linear-regulated 12V/3A PSUs and just split the left and right line signals.
About the bass mod, I saw a new thread here about t-amps with a new pcb layout. When I will re-case the amps and replace the cable connectors, I'll also find out what version of the board I got.
Old 3rd August 2007, 10:50 AM   #12
I will simply power my t-amps each with it's own Mascot linear-regulated 12V/3A PSUs.
have you checked that the transient peak output current from the amp to the speaker can be met by this SMPS? 3A is very low unless peak current demand is met from some other component.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 3rd August 2007, 11:44 AM   #13
diyAudio Member RIP
Originally posted by gofar99
Greetings everyone, No where in the discussion do I see any crossovers.
gofar99
That is because it will not work well. You cannot replace the speakers
internal crossover with an off the shelf electronic crossover with fixed
electrical slopes, you would need a bespoke electronic c/o that would
match / improve on the speakers internal passive crossover.
/sreten.
Old 3rd August 2007, 11:55 AM   #14
Pano is offline Pano  United States
Pano's Avatar
This is very true! A lot of work and a bit of magic goes into making a good passive crossover. The specs may give you a nominal crossover frequency, but that is not the whole story. There is a lot going on in a good passive x-over. You might not be able to duplicate it in a simple active crossover.
That's what big caps are for! In reality, the amp will draw about 300mA for music into 8 ohms. But peaks can draw much more. That's why you need the amperage. Good, fast caps can help supply the peak current.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 3rd August 2007, 02:39 PM   #15
I agree.
What has Mustik planned?
regards Andrew T.
Old 3rd August 2007, 07:40 PM   #16
gofar99 is offline gofar99  United States
Greetings again, My oversight, All my systems have external (or none at all) passive crossovers and I made the assumption that you would be driving the speakers directly. If you are using the internal passive crossovers then the use of an external electronic one is not the way to go.
Good listening
gofar99
Old 4th August 2007, 08:21 AM   #17
I have a new revision D board. According to this thread it should be easy to mod. However, for me it's impossible for me to follow the provided instructions, so I will have to wait until there are pictures available.
Old 5th August 2007, 10:57 AM   #18
Hi
I got my other Mascot psu back from a friend yesterday and just did the bi-amp trick few minutes ago. I set up the test system like this: PC line-out (integrated nVidia nForce) -> Y-splitter -> t-amps. I set the amps to full volume and used the master volume on pc to control volume of both amps.
The mids still sound a bit harsh to my ears, but since everything from proper input/output connectors to input cap mod to having better quality equipment signal to "burn-in" is yet to be done, I think it will get a lot better.
One thing I noticed (If I did not imagine) after moving to two amps feeding them with separate 12V/3A psus was that bass seems to come out better.
FS: Sonic Impact T-Amp oldman1 Swap Meet 2 6th December 2007 06:53 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
Sonic Impact T-Amp - Is bi-amping better? ac2005 Class D 1 29th July 2005 09:28 PM
Bi-Amping with Sonic Impact? blip Class D 0 1st March 2005 11:49 PM
Copyright 1999-2017 diyAudio
