>>when I put a tube pre in front of it it just has more drive<<
I have a hybrid tube/ss int amp. Compared to my Panny XR50, the hybrid just doesnt quite have the detail. The hybrid doesn't put up as focussed of a soundstage as the Panny either.
That was my reason for experimenting with a passive. I want detail and a tight soundstage. I plan on building a Hypex class-d amp along with the passive preamp. My fear is that the passive might be too thin. The passive is cheap enough to build so I can accept failure if the resuslts are not to my liking.
JimOfOakCreek said:The passive is cheap enough to build so I can accept failure if the resuslts are not to my liking.
And you might build with enough space to go to an active preamp later. Just a little rewire to turn passive into active.
I have such a preamp (it ain't pretty) that can be switched passive or active. In other words, the active circuity can be bypassed but all the connectors, volume pot and input selector remain the same.
I have an NVA Pre Amp, driving a slightly modded Trends TA10.1 in power amp mode. I do have to push the volume up, but it works perfectly well, with the NVA. i am however lacking a little bit of power, so may buy an autocostruire t100hcl module and , get a transformer, etc, to get the extra oomph, from the klipsch speakers.
I'm thinking of builing a Hypex based power amp and was also wondering what preamp to use with it.
I asked Hypex what they thought about it and they suggested that if I build passive preamp that I should use 10k pot or stepped attenuator. They also pointed me to the active preamp, with remote control, made by MM Audio, that also produce a range of Hypex based power amps: http://www.mm-audio.nl/
CI Audio use a passive preamp with their Hypex based amps. There are two versions, one remote, one manual, but both use 10k Alps RK27 (Blue velvet) pots: http://www.ciaudio.com/
Personally, I like remote control and I came accross these remote control preamp kits while looking around: http://electronics.dantimax.dk/Kits/Preamps_-_poweramps/index.html
10K Ohm Goldpoint Stepped Attenuator
I've never actually tried a stepped attenuator, I've always wondered whether 24 steps will be enough. I'll be interested to read your views when you have it up and running.
Here's a nice remote controlled passive preamp with 60 steps: http://www.bentaudio.com/index2.html. There is also a kit version, although they are both fairly pricey; it certainly looks the part though.
Passive Pre with UCD180ADs
Hi
I've been using the DIY Paradise Maggie passive (autoformer) preamp with my dual mono Hypex amp for about six months.
Very good, no problems, didn't even check the impedances matched (forgot it might be an issue). Prior to this I had bashed together an Alps Blue pot based passive - worked fine but no comparison to the transformer approach.
MAW
Hi
MAW
- Class D
- Passive Preamp With Class-D
