Max PSU voltage with SI T-amp
Old 1st July 2007, 02:06 PM   #1
jives11 is offline jives11  United Kingdom
jives11's Avatar
Default Max PSU voltage with SI T-amp
anyone have any idea what the maximum safe voltage you can use with the SI T-amp ?
I have a failry beefy 15v DC supply and wonder if it's saafe to use. T-amp says 12v but not sure if it has any safety/regulation
Old 1st July 2007, 09:37 PM   #2
Pano is online now Pano  United States
Pano's Avatar
15 volts will cook it.
I don't like to go much over 13V. Some guys have run them at 13.8V without immediate trouble, others have fried the chip.
I would consider 13.8 to be the limit of what is safe, but feel better about lower voltages.
Take the Speaker Voltage Test!
Old 2nd July 2007, 02:12 PM   #3
Buckapound is offline Buckapound  United States
I tried different voltages and was checking the chip temperature with an infrared thermometer. I did have a small aluminum computer memory chip heatsink on it.
I had one running at 13.8 volts, but the chip generated quite a bit of heat. At 14v it went into thermal shutdown. I eventually decided on 13.2v. At this level, the chip ran at least 10-15 degrees C cooler than at 13.8.
While the chip does have thermal protection, word is that continued operation at high temperatures will eventually degrade/destroy the chip.
--Buckapound
Max PSU voltage with SI T-ampHide this!Advertise here!
845 Low voltage SE AMP =maximum= Tubes / Valves 16 20th January 2013 03:31 AM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 05:56 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 04:56 PM
secondary voltage vs. primary voltage Stocker Parts 5 11th March 2004 08:41 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 23rd July 2002 12:50 AM
Copyright ©1999-2017 diyAudio
