The Boominator - another stab at the ultimate party machine
Old 30th December 2013, 04:41 PM   #4471
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Contact
Old 30th December 2013, 05:46 PM   #4472
croowley is offline croowley  Sweden
Originally Posted by Saturnus View Post
Great, thanks! Btw is ther a recomended solar-regulator for lifepo4?
Old 2nd January 2014, 07:31 PM   #4473
Wennen is offline Wennen
Hello everybody!
I have been reading this thread for a while now but I haven't been able to understand what cable that is used to connect the battery to the amp6? Does anyone know the answer to that?
Thanks in advance!
Old 2nd January 2014, 08:04 PM   #4474
lutkeveld is offline lutkeveld
normal speaker cable. 2x1.5mm2 for example will do the job just fine.
Old 2nd January 2014, 09:48 PM   #4475
Okay, so I need to sold the cables directly on the board instead of inserting the powercable in the "power jack" that comes with the amp6-basic kit?
Like this?
http://www.diyaudio.com/forums/class...chine-335.html
Old 2nd January 2014, 09:58 PM   #4476
Image is dead. You could solder a DC jack onto your power leads, but I would prefer soldering because it's more solid.
Old 2nd January 2014, 10:04 PM   #4477
This was the picture (post nr 3343), hope this works!
Ok, Thanks a lot lutkeveld!
Old 2nd January 2014, 10:12 PM   #4478
Saturnus's Avatar
Nope. Right click, open image, in image brackets post the url
Old 4th January 2014, 07:06 PM   #4479
torclausen is offline torclausen
Default battery question..
Long time reader... thanks everyone for all the postings...
I've enjoyed on board crossovers for simplicity, so I'm excited to try this new board.... 2013 Class D Amplifier Board TPA3116 2 1 2X50W 100W | eBay
As has been stated here... the board can't take two SLA batteries (13.5x2 exceeds its voltage limit)
What are my options? I ordered 12 AA NI-HD ebay batteries to test with, but that won't play long. I'm also at a loss on how to charge 22-ish volts. I found a cheap 18v ni-mh charger for rc cars, it doesn't state its actual voltage.
Again, thanks so much for everything!
Tor
Old 4th January 2014, 07:34 PM   #4480
Saturnus's Avatar
6 lifepo4 cells are 19.2V nominal and 21.9V fully charged. Seems like a shoe-in.
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
Copyright ©1999-2017 diyAudio
