The Boominator - another stab at the ultimate party machine
Old 16th September 2013, 11:37 PM   #4251
pkozul is offline pkozul  Australia
Default Qubinator completed
Hi again,
We managed to finish one of the Qubinators. All photos of the build are here:
Qubinator - a set on Flickr
We used a textured spray paint (granite) which turned out pretty good. This first Qubinator is for my friend, who will be spray painting some patterns over the top using a dark colour.
Now I need to focus on mine (the one spray painted using a black texture). Need to solder bits and pieces together and mount them in the box.
We fired up the completed Qubinator in the backyard. Went pretty loud, and we didn't want to max out the volume due to the neighbours.
Since these Qubinators are using the TA2024 Bluetooth amps (by Helder hifi), we ended up soldering the appropriate pins together beneath the 3.5mm stereo input connector (thanks to the suggestions on the other thread), to allow Bluetooth to work regardless of whether am audio cable is plugged in or not.
Look forward to completing mine, and then finally being able to enjoy it just as Spring time is kicking in here...
Pete
Old 18th September 2013, 07:33 PM   #4252
Keithus is offline Keithus  Ireland
Hi guys
I'm planning my boomanitor at the moment.
And I would really like to install a radio in mine.
As well as a Bluetooth reciver.
What do people think of this and any suggestions.
Here is something I've been looking at
Digital Bluetooth Audio Receiver Board With Fm Mp3 - Buy Digital Bluetooth Audio Receiver Board,Digital Bluetooth Audio Receiver Board,Digital Bluetooth Audio Receiver Board Product on Alibaba.com
Old 20th September 2013, 02:22 PM   #4254
nusma is offline nusma  France
Hi everybody,
Thanks to Saturnus, i am waiting for 4 HP10W from bluearan !!
And also 4*KSN1005A !! Everything should be there next week, and i am waiting for some information from 41Hz.com.
@Mikalo, i plan to build the same Boominator (the standard one). There is no crossover except the 150ohm resistors for the tweeters? No filtering for the HP10W?
My configuration will be HP10W and KSN1005, i did not find the crossover for this configuration (sorry, i think it is in the thread but i can't find it... )
Thank you for you answer!!
Manu
Old 23rd September 2013, 02:08 PM   #4255
Boomigator is offline Boomigator  Netherlands
Is there a difference between these speakers:
Old 23rd September 2013, 07:16 PM   #4256
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
No. I think you'll find the intertechnik picture is quite old (at least 6-7 years out of date) and not of the HP10W as it looks today.
Old 24th September 2013, 03:35 AM   #4257
mikalo is offline mikalo  Australia
I would also like to use the boominator for Djing. Does anyone know if there will be a problem in reducing two 1/4" ts (mono) plugs down to a 3.5mm trs plug? If not, why cant I find the adapter online? (2x 1/4" ts female to 3.5mm trs male)
Found it Hosa YMP-137 Stereo Breakout 3.5 mm TRS -2x 1/4 in TSF on eBay!
Old 24th September 2013, 06:34 AM   #4258
Saturnus's Avatar
Correct. No crossover needed. However, the series resistor should be 47ohm with a ksn1005 or replica.
Old 24th September 2013, 07:28 AM   #4259
Well ... I have to say everything is in hand my know!
Thanks a lot for your time and explanation Saturnus.
Manu
Old 24th September 2013, 11:55 AM   #4260
Another question about the amp6 basic (not assembled)
I tried to join the support from 41Hz, but no reply since to weeks. I would like to order this amp for sure, but it is said that some little mods have to be done to plug low output device like an iphone.
Some of you should have done this mods, could you explain me which components i should replace? I can order the amp and buy on my own the good components.
I have read that we can change also the input caps to get a better DC filtering. Which one should i change (--> where it is? ) ) by which value?
Thanks for your help,
Manu
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
Copyright ©1999-2017 diyAudio
