The Boominator - another stab at the ultimate party machine
Old 5th March 2013, 04:22 PM   #3531
aml417 is offline aml417
Originally Posted by Saturnus View Post
Not unless you have the 2x HP10W speakers on the same side. If you do then baffle step is 383hz.
Isnt that for a baffle with 300mm in width only? And why isnt the hight of the baffle considered? The low frequency soundwaves should "bend" over these edges aswell, shouldnt they?
Old 5th March 2013, 05:13 PM   #3532
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
The width is the height
Width is this respect is just a flexible term that means the smallest dimension as a normal speaker would be higher than it's wide, width is used as synonymous with the smallest dimension. In the Boominator, the smallest dimension is the height instead.
Old 5th March 2013, 05:18 PM   #3533
Ok, thanks for the answers Saturnus, you really cleared things up for me!
Old 5th March 2013, 05:25 PM   #3534
xybercoke is offline xybercoke
Quick question, i'm looking to buy the amp6 basic, from 41 hz. Should i buy the preassembled version or the basic kit? There description does not tell me a whole lot about the difference other than its all assembled...
Old 5th March 2013, 07:44 PM   #3535
Svampan is offline Svampan  Denmark
Originally Posted by xybercoke View Post
... description does not tell me a whole lot about the difference other than its all assembled...
There you go. Welcome aboard
@Flipboy02
It's a very fine illustration you've made, however I find it somewhat confusing. I know you're going for a very in-depth, compact, all-in-one, highly visual representation, however I think it may confuse you more than necessary. I know you try to be as prepared as possible, but I think you should just order the parts, start the project, and figure things out as you go along. Then when the beast is done, you can make a new diagram with all the knowledge you've acquired - that would be really helpful.
I don't know if paralleling the resistors in the crossover is done as you've illustrated it, will have to google some more.. And remember the tweeters should be inverted as per Magnolio's diagram:
Could you elaborate on this saturnus? I've been trying to figure out what the purpose of inverting the tweeters is. Thank you for your help, learned a lot about crossovers in the last few days
Old 5th March 2013, 10:10 PM   #3536
wy2quiet is offline wy2quiet
Oh yeah...
Small video of her running..
https://www.facebook.com/photo.php?v...79767059319976
Old 6th March 2013, 03:09 PM   #3537
booom is offline booom
What do i need, and how do i connect two boominators so they can run from the same music source?
Old 6th March 2013, 04:02 PM   #3538
Assuming you are running a tripath in each, you use an RCA splitter, and run the same output (iPod, etc) simultaneously to each.
Heads up for those looking for batts. I just bought 4 of these cells, and paid $120 shipped to Canada
Lifepo4 40155 cells with high power and large capacity _LiFePO4 Batteries_E-Bike Batteries_A123 RC Battery|High Quality Battery|Wholesale Ebike Battery
15AH Lifepo4, with battery bars for easy install. According to endless-sphere forums these batts give around 14-15ah at 10C discharge current (150amps).
Old 7th March 2013, 09:35 AM   #3539
joeoz is offline joeoz  Australia
Originally Posted by gmarsh View Post
I use a 19V laptop power supply to feed the solar charger in my Boominator for home charging. I use a separate solar panel which plugs into a connector on the box, laptop adapter plugs in there instead of the panel. Pretty simple.
Hi all,
This sounds like a good way to cater for the charging options. I don't have a spare laptop power supply, so I was wondering whether I could use my SLA battery charger instead. Would these two options work (interchangeably)?
A) 12V SLA battery charger -> (DC jack) -> solar charge controller -> SLA battery
B) 12V solar panel -> (DC jack) -> solar charge controller -> SLA battery
The common connection point would be the (DC jack) which is a female connector on the boombox itself. So, you could either connect the SLA battery charger using trickle charge (when running off mains) or disconnect it, and then connect the solar panel instead (when out and about).
So, the question is... can I use an SLA battery charger in this way?
Thanks!
Joe
Old 7th March 2013, 09:55 AM   #3540
Saturnus's Avatar
No. An SLA charger measures the battery while charging. Putting it in front of the solar charger will make it unable to detect the battery so it won't turn on.
A solar charger just needs a DC supply of sufficient voltage. You can probably find dirt cheap second hand laptop supplies on ebay.
One such as this. 16 aussie dollars including shipping seems like a fair deal (although you can ask if you can get it cheaper if you pick it up yourself seeing as it's in Melbourne as you). http://www.ebay.com.au/itm/90W-LAPTO...item337ef24b6d
Or a chinese multi-thingy with all the plugs and voltages you can dream for roughly the same. http://www.ebay.com.au/itm/Universal...item5653ced071
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
Copyright ©1999-2017 diyAudio
