The Boominator - another stab at the ultimate party machine
Old 2nd March 2013, 03:59 AM   #3511
blossom is offline blossom  New Zealand
blossom's Avatar
Originally Posted by stevodude View Post
Well I did what I should have done from the start, and that is order 2 x AMP6's from 41Hz.
Actually ordered 2 AMp6 basic sneaky's, ended up an ok price ~ $115aud total for 2 sneaky's delivered with insurance.
S.
Thats sounding better!
Old 2nd March 2013, 12:56 PM   #3512
wy2quiet is offline wy2quiet
I still can't get over how LOUD 15 watts is. I run 140w a DRIVER in my car, which can get loud, howeven taking into effect the efficiency of the drivers I chose (~95db) I guess it makes sense. As I said before, at 1/4 volume on the TA it is a VERY comfortable listening volume. Half volume is annoying.
Old 2nd March 2013, 01:05 PM   #3513
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
It's an efficient little beast
Old 2nd March 2013, 01:08 PM   #3514
Have you ever had a problem with the high's being a little recessed? Do the piezos maybe need to be broken in? I am thinking maybe they (piezo's) are a little less efficient than I thought, or the woofers are more sensitive than I calculated. I did use a 47ohm resistor for each piezo as you mentioned.
I have a calibrated mic that is 0.5db 20hz-20khz maybe I should use Room EQ and sine sweep for response.
Old 2nd March 2013, 01:15 PM   #3515
Saturnus's Avatar
You can try with a small resistor if you like but frankly I prefer it with a little lower highs. A smaller resistor won't give much extra output though. Just a little bit but it'll also make it more annoying when listening to acoustic or vocal music. A smaller resistor works best if you play mainly electronic music.
Old 2nd March 2013, 01:21 PM   #3516
I am playing Norah Jones now and it sounds perfect. Good call, sibiliance isn't bad.
Old 2nd March 2013, 01:32 PM   #3517
Saturnus's Avatar
If it's measured indoors a frequency plot isn't pretty. Much better linearity when outdoors as intended. That's not to say that it flat by any hi-fi definition but it sounds remarkably well regardless. Then again, my Fostex FE206e which were used as reference in the design aren't flat either.
It's intended to to have really good bass performance (except for the really low bass which is missing completely although you most of the time forget that), and sound very natural on voices in particular and in the midrange in general. I am especially proud of the way it handles brass instruments and female voices which are notoriously difficult for a speaker to get right.
Old 2nd March 2013, 01:37 PM   #3518
Yeah I was just surprised since I used different drivers. Here is the PDF plot of the FR from the manufacturer.
http://www.mcmelectronics.com/conten...ts/55-2961.pdf
As I said, I am considering not even using the inductors I bought, it seems to roll off rather smoothly and sounds fine.
Old 3rd March 2013, 05:34 AM   #3519
stevodude is offline stevodude  Australia
Send a message via Yahoo to stevodude
Bit stormy today, but had to test it outdoors. Loving a bit of 'Momentary lapse of reason'.
Sent from my XT925 using Tapatalk 2
Old 3rd March 2013, 08:54 AM   #3520
brummiejon is offline brummiejon  United Kingdom
Default Solar panels
Hey stevodude, looking good, how does it sound?
Just spotted these on ebay.....
5W Solar Cell panel for diy boat motorcycle 12V Battery Charger Mono crystalline
http://bit.ly/YLFJw2
They look ideal......
BJ
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
