The Boominator - another stab at the ultimate party machine
Old 27th December 2011, 05:10 PM   #2511
HifiBoyDenmark is offline HifiBoyDenmark  Denmark
Originally Posted by Saturnus View Post
Actually the amp6 (or any other TA2020, TA2021 or TA2024) uses about 360mA
The calculation is pretty simple, it just assumes an average music level at -10dB (-9dB dynamic gaussian signal normalized to -1dB). So it's just V^2/(Z*10) to have the power consumption of both channels at full music power output. That's 300mA. To that you add the quiescent current consumption which for the TA2020/2021/2024 is 60mA, so 360mA total (assuming the amp has no LED to indicate power, otherwise add 20mA).
For the above amp, assuming the same battery, the output will be the same since the supply voltage is the same so the load consumption is also the same at 300mA but quiescent for the TP2050 chipset is 185mA plus the LEDs beside the potentiometer which uses 40mA so 525mA total.
So about 50% more consumption at the same maximum power output. However, the interesting thing is that the idle consumption is totally different; amp6 in idle uses 60mA, the above amp uses 225mA in idle. Almost 4 times as much.
thank you very much! again
Old 27th December 2011, 05:17 PM   #2512
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Originally Posted by gmarsh View Post
Cool. The 120mm hole for the speaker magnets in your Sketchup drawing won't do for the speakers, but I hope anyone building the Boominator and using the GW1058s will notice that in a hurry.
You'll also notice that you don't need the magnet cut-out with the GW1058s because they're shallower than the original HP10Ws so they wont actually reach the center brace
You should cut-out a piece of wood to put on either side of the center brace, 12mm (0.5") so that the magnet is in direct contact with center brace on the GW1058s. This can be done from the speaker cut-outs you have left from the sides.
Old 27th December 2011, 07:38 PM   #2513
aaroe is offline aaroe  Denmark
aaroe's Avatar
I'm considering four of these in series/parallel for mine, giving 21 chinawatts of solar power. They lack the connector "box" that the Sparkfun panel has which makes routing the top a bit easier:
5W Monocrystal Solar Panel 12V Battery Charge 5.3 Watt [5.2W] - $30.26 : Zen Cart!, The Art of E-commerce
I'm also considering bare 3x6" solar panels embedded in the top. You could fit 15 in the top, giving close to 30 watts. Maximum power voltage will be ~7.5V so you'll need a boost mode MPPT charger like a ST SPV1020.
There's also lots of 20W monocrystalline panels kicking around that'll fit the top, eg:
20W Mono-Crystalline Solar Power Panel with 12V Charger Controller - Solar Power Panels
That China-panel has the perfect dimentions to fit the boominator only problem is, that its monocrystal. I think I'll stick to a larger external amorpheous panel as mentioned earlier.
Old 28th December 2011, 06:06 AM   #2514
aaroe's Avatar
Btw, I forgot to ask you guys, what kind of glue is recommended around the edge between the speaker, speaker grid and the cabinet, if you understand...?
Besides the glue, I'm planning on using unbraco or torx bolts through the cabinet, tightened with a nut on the back side. This should hold the speaker in place, so the main purpose for the glue is actually just to make the jointing airtight.
Old 29th December 2011, 11:46 AM   #2515
aaroe's Avatar
Anyone who has an estimate on how much juice this voltmeter uses?
Is it worth the coolness, or is it a power drainer?
2.2" LCD Digital Panel Voltmeter with Blue Backlight (7.2~20V) - Free Shipping - DealExtreme
Old 29th December 2011, 12:30 PM   #2516
kblnig is offline kblnig  Denmark
I would make a switch for it turn it on if you need to see the status on your battery and then flip the switch when done
Old 29th December 2011, 02:27 PM   #2517
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
I'd estimate 10mA for voltage regulator and micro, and 20mA for LED backlight, for 30mA total. As mentioned already, I'd put it on a switch.
Old 29th December 2011, 09:19 PM   #2518
aaroe's Avatar
Thanks for the replies... I'm definitely gonna put it on a switch :-)
Old 29th December 2011, 09:36 PM   #2519
Kostecki is offline Kostecki  Denmark
We've got a homemade voltmeter on our boominator so we have this switch: ProSwitch - Vandalsikret stålkontakt, 1P OFF-(ON) Ø16 Hvid
It's on off-(on) switch so the voltmeter is only on when the button is pushed until you release it again. This way we don't have to worry about drunk people forgetting to turn it off
Old 29th December 2011, 09:38 PM   #2520
aaroe's Avatar
Good idea :-)
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
Copyright ©1999-2017 diyAudio
