The Boominator - another stab at the ultimate party machine
Old 22nd June 2011, 02:15 PM   #1921
rubennn is offline rubennn  Denmark
Originally Posted by chief3 View Post
The inside width of my box is 27,6 and my speakers are, when glued together, 26,6... should i get 1 cm og linolium and stick in between the magnets or should i get 0,5 plywood and make the "fitting circle" thicker ?
i only have the 5ply 12 mm wooden board and i have not made any cuts yet.
any suggestions how to fit the boominator mark 2 with the new design HP-10 w ?
thanks everyone
It has been discussed before.
Use masonite board between the cabinet wall and the speaker (this is usually 3,5-4 mm thick) and then combined with the speaker grills you should be able to fit them there just perfectly. Otherwise... Use your imagination..
Wohoo...Boominator 2012
Old 22nd June 2011, 03:50 PM   #1922
chief3 is offline chief3  Denmark
sorry but thanks for the answer.
does anyone have experience with the ebay piezoes which saturunus recomemnded once and then they went out of stock. ?
because im not sure if they need an ohm resistor ?
Old 22nd June 2011, 04:02 PM   #1923
Falken is offline Falken  Sweden
Originally Posted by rubennn View Post
I would assume that you were going to Roskilde Festival? And you want to build a stereo before that with items from parts-express.com? It's in the US, so there's no chance that you will have them in time.
If you're going to another festival and/or you are building your stereo later, then don't mind this post.
No not going to festival
No I have not in a hurry, but it seems pretty hard to get hold of Horn bubble tweetwers / Motorola.
Anyone know where to buy them without waiting for 30 days?
I ordered 4 pieces Paudio HP-10W a month ago from PLUS Elektronik.de
the last 2 weeks they claim that they have been on mission,
and this week they claim that it is off all week??
appears to be an extremely frivolous small businesses with few employees?
no service culture.
Falken
Old 22nd June 2011, 07:40 PM   #1924
Finished and ready to go Sound quality is nowhere near the original boominator, but it's still loud, and that's the most important thing for me and my camp. It's the 8 ohm system so it will drain half the power and thus play half as loud (-6 dB).
I'm pretty satisfied with the weight and size. It's easy to carry around And the LED light is kicking aarsh in the dark. But still, Saturnus. The first boominator I built had way better sound quality - even with replica piezos.
I will go for the full boominator next year, just didn't make it this year because of the out of stock problem in Europe.
Thanks for answering all my posts and helping me out with difficulties, free beers on me
Pics are here:
See you at the boominator meet up! Looking so much forward to it !!
Have a great festival
Old 22nd June 2011, 08:11 PM   #1925
PressureFM is offline PressureFM  Denmark
PressureFM's Avatar
The happy bunch!
Class D Amp Pr0n
Unfortunately I don't get to take the AMP9B with me this time around, as it simply takes too much power for the batteries I have.
So AMP6B and the Lepai 2020A it is.
Old 23rd June 2011, 11:58 AM   #1926
donnib is offline donnib  Denmark
I am about to buy this panel KeryChip WEBSHOP - solceller, solcelleanlæg, tilbehør which the shop said that i could take of the frame and get down to about 44cm x 29cm which is almost exactly as the size (on one dimmension) of the Boominator box.
What would you recommend i do to mount it ? Should i bother to use the router and dig in 35mm depth so i can fix it in the wood on top of the boominator ? The issue is that i do not think i use the router and leave only 1mm wood left on the side with 30cm.
Ideas are welcome
donnib
Old 23rd June 2011, 02:54 PM   #1927
If you have more than 35 mm thick ply you can route the panel in :P That's almost 3 times the thickness of the ply recommended for the normal boominator.
Honestly I just think you should fasten it with screws on top, so it's also easily removable. Your choice.
Old 23rd June 2011, 02:58 PM   #1928
Ups.... silly me. You are right. Well well.... will see when i get it. I guess it's not 35mm thick without the frame but will see. It just looks silly on top i think.
Old 23rd June 2011, 03:14 PM   #1929
No it doesn't
Here's a pic from Darkwithin's panel
http://i1080.photobucket.com/albums/...3-04130443.jpg
It's not the same panel though.. But I still think solar panels look pretty sexy.
Old 23rd June 2011, 04:56 PM   #1930
I actually just tested how affected the treble was by my wide, slim horn going from 1800-20000 hertz. It's actually pretty noticable when going from side to side and it laying flat on the ground as it does on the pictures. Though if you raise it up, santding on the side without the port, it's not as bad.
It's also starting to sound better than before. I guess the burn-in effect deals a bit with the crappy sound right now. But it's worthwhile to think about before making a stereo like mine using these kind of horns. I'm still rather new to hifi, but dispersion will definately be a valuable consideration from now on.
Thanks for pointing it out, Saturnus (was some time ago)
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
Copyright ©1999-2017 diyAudio
