The Boominator - another stab at the ultimate party machine
Old 20th June 2011, 07:59 AM   #1871
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Originally Posted by Kostecki View Post
I'm sorry for "double-posting" but i can't just let my question drown since i really need some clarity on this
What material is it? Those driver look like the suspension is made of some kind of synthetic rubber. In that case head to your local hardware store and ask how to repair it but you might get away with just using a small strip of extra strong duct tape. Or regular duct tape and one component contact glue.
Old 20th June 2011, 11:14 AM   #1872
Boissez is offline Boissez  Denmark
Default Battery musings...
Hello everybody, first time poster here.
I've been reading back and forth in this thread (and around the webs) but I have a hard time gauging what kind of battery life to expect from different battery solutions.
What I wan't to build is an 'airline-friendly' setup (must fit in overhead compartment, max 5-6 kg). It's somewhat more classic than the boominators here but I'm looking for a setup that can double-duty as a real audio player when travelling - so stereo is a must.
Here are the components I'm considering so far:
- Hifimediy T1 or T2 (TK2050) - (not sure which to get )
- 22.2V LiPo Battery (ca. 4000 mAh) + balanced charger
- 2*JBL control 1Xtreme monitors (have those already) 8 Ohm, ~90db
My (totally unqualified) guesstimation is that I can count on about 2-3 hours battery @max and 20-30 hours @ more conversational levels.
Question is now... Am I completely wrong? And what would you suggest I do differently to optimize battery life?
PS: I apologize in advance if this is the wrong place to post this. I simply figured that people in this thread would have a great deal of experience with class D's + batteries.
Old 20th June 2011, 12:25 PM   #1873
Saturnus's Avatar
That's slightly optimistic. 2 hours @max should be doable but only 10-12 hours @ very low volume.
I'd advice to get much more sensitive speakers though as those you have will probably mean you use way too much power by needing to turn it up higher.
Old 20th June 2011, 01:29 PM   #1874
I was fearing somebody would say that... But thank you for confirming my fear
Problem is that tiny efficient speakers are few and expensive - not something I'd travel with. Frankly, I haven't found any other speaker that really beats these in terms of efficiency vs size/weight (they are only 2.35 kg each and 23x15x14cm).
It does trigger another question though: would using a smaller amp help? I know these are supposed to be ~90% efficient - but does efficiency drop noticably when it plays at say 10% volume?
Otherwise I guess that I'll just have to tone down expectations and try to fit a larger battery to the amp.
Old 20th June 2011, 01:45 PM   #1875
Wubbaz is offline Wubbaz  Denmark
Sorry for asking this again, but I am in doubt of how I should make the central connection point.. just take all plus wires to a buttsplice and then take all the minus wires and then into a buttsplice? Red is plus, blue is minus
Thanks!
Old 20th June 2011, 01:52 PM   #1876
Saturnus's Avatar
Correct. Except for the small change. Note the connection on the batteries.
Old 20th June 2011, 05:15 PM   #1877
Cheers, Saturnus! Just need to fit the HP-10W's and the electronics, then I'm finished.. won't be able to paint it before Roskilde
But thanks alot for all the help you have been! Really appreciated
Old 20th June 2011, 07:51 PM   #1878
donnib is offline donnib  Denmark
Post Maybe this could help new people doing this
I have read this thread many times and other threads about Boominator and i have gathered a list of important/interesting posts, parts etc for the Boominator project.
I cannot say that i am ready to my Boominator yet although i have ordered parts i still have allot of unanswered questions about the case which is the thing that gives me the biggest headache since there is no exactly design of it with size (i want to build the same design as Saturnus made with some minor modifications). I'll get back with question about this in another post.
Parts
Grill
https://elextra.dk/main.aspx?page=article&artno=H19318
Enclosure for amp6basic
Velleman nv
Sunpanel
Accubescherming op Zonne-energie 15W - Accu beveiliging & onderhoud - Conrad Electronic
FRYS.com*|*SUNFORCE
Glue for panels
http://www.tec7.dk/produkt-sortiment...ter/tec-7.aspx
Fuse for amp6basic
https://www.elextra.dk/main.aspx?pag...e&artno=H15563
Good links to parts (2009)
http://www.diyaudio.com/forums/class...ml#post1718431
Good list of parts needed by Saturnus
http://www.diyaudio.com/forums/class...ml#post2366742
Tools
Router (fræser)
https://elextra.dk/main.aspx?page=article&artno=H22748
Interesting and important discussions + useful information
Explanation on Solar Power Rating
Solar panel power rating
Discussion on power consumption
http://www.diyaudio.com/forums/class...ml#post1679997
Port size and top
http://www.diyaudio.com/forums/class...ml#post1679847
Information on brace
http://www.diyaudio.com/forums/class...ml#post1680882
http://www.diyaudio.com/forums/class...ml#post2478757
Why use the resistor
http://www.diyaudio.com/forums/class...ml#post1676491
Effect of the resistor
http://www.diyaudio.com/forums/class...ml#post1882246
How to calculate the right resistor for your boominator
http://www.diyaudio.com/forums/class...ml#post1862795
Diagram of piezo/driver and resistor
http://www.diyaudio.com/forums/class...ml#post1878867
http://www.diyaudio.com/forums/class...ml#post1742547
Tip for piezos
http://www.diyaudio.com/forums/class...ml#post1885911
Why magnet-to-magnet construction
http://www.diyaudio.com/forums/class...ml#post1738505
http://www.diyaudio.com/forums/class...ml#post1862802
More on resistor, magnet-to-magnet etc
http://www.diyaudio.com/forums/class...ml#post1873631
Information about the case
http://www.diyaudio.com/forums/class...ml#post1679589
Why amorphous solar panel ?
Battery powered amp
How to create the cabinet and making an nice finish (Danish)
Sådan samler du et kabinet ordentligt og laver et pænt finish | Roskilde-Open
Size on the box
http://www.diyaudio.com/forums/class...ml#post2102290
http://www.diyaudio.com/forums/class...ml#post2192739
http://www.diyaudio.com/forums/class...ml#post2202014
Cutting instructions by an user
http://www.diyaudio.com/forums/attac...ator_cuts2.png
PA Audio changed design on driver
http://www.diyaudio.com/forums/class...ml#post2480460
Google SketchUp drawing made by Saturnus
The Boominator mark II by Saturnus - Google 3D Warehouse
Building process and end result by users
Building process from an user
Image hosting, free photo sharing & video sharing at Photobucket
http://www.diyaudio.com/forums/class-d/104402-boominator-another-stab-ultimate-party-machine-74.html#post2295893
http://www.minhembio.com/forum/index.php?showtopic=262694&view=findpost&p=2909234
http://www.diyaudio.com/forums/class...ml#post2550455
Old 20th June 2011, 10:57 PM   #1879
Phaedras is offline Phaedras  Denmark
Phaedras's Avatar
Originally Posted by donnib View Post
Wow, thats a lot of links gathered, good job
I notice you also added a link to my cabinet blog entry - i'm glad its helpful
Old 20th June 2011, 11:28 PM   #1880
Phaedras's Avatar
I would like to remind people of the Boominator Meet-Up @ Roskilde Festival. Its Tuesday the 28th of June, at Agora G @ 15:00 (3pm)
Meet-up!
Also, go check out the Boominator facebook page for pictures and stuff
Boominator Facebook
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
