The Boominator - another stab at the ultimate party machine
Old 11th June 2011, 08:15 AM   #1751
Smoothy is offline Smoothy  Sweden
Just to be on the safe side here. There seams to be 2 different GoldWood GW-1058 but i can only find one of them on goldwoods homepage.
Is it
Goldwood GW-1058 10" Pro Woofer
or
Goldwood GW-1058: 10" 200W "Huntington Series” Woofer, Discount Prices on Goldwood GW-1058: 10" 200W "Huntington Series” Woofer
I was under the impression that the later was recommended by Saturnus but the first one also would do the job.
Its a bit troublesome when the model name is exactly the same.
Old 11th June 2011, 07:41 PM   #1752
joak0068 is offline joak0068  Denmark
Does anyone know if these batteries would be good for the price?
12V - 12Ah Deep cycle : Batterishoppen: Holdbare og billige batterier
Or is there anything better
EDIT: They're sold out
Can you recommend a battery for a "crappy edition" boominator
Old 11th June 2011, 08:14 PM   #1753
Wubbaz is offline Wubbaz  Denmark
I bought 2 of these: Yuasa NP7-12 - 12V - 7Ah (F187 4.8mm) -
Free shipping if you live in Denmark.. These are quality batteries, and they're not that expensive. I recommend them. :-)
Old 11th June 2011, 08:30 PM   #1754
ZFRaudio is offline ZFRaudio  United Kingdom
or yuasa NPC range if you want the (better quality) deep cycle variant
depends on the budget! I have also had very good experiences with the NP7 and NP24
Old 11th June 2011, 08:34 PM   #1755
I have a few battery questions regarding the Boominator..
1. Can you play music while charging the batteries with solar cells?
2. Is it safe to smoke near the Boominator while it is charging?
3. Is a charge regulator needed for my batteries? I have 14Ah in total and 10W solar panels?
Thanks in advance
Old 11th June 2011, 08:55 PM   #1756
Thanks for the advice I'm on a pretty tight budget, so i bought 3 of these instead of the NPC..
Old 12th June 2011, 10:30 AM   #1757
rubennn is offline rubennn  Denmark
Saturnus, I've seen you recommend different values of resistors to different piezos. I was wondering if there's any way you calculate this with an equation?
Afaik, piezos are different (with different capacitance values) and a crossover with a resistor is unique to each piezo. Therefore the capacitance should be measured.
I've been looking for online calculators but have not found anyone for piezos in particular. That's why I'm asking here now
Wohoo...Boominator 2012
Old 12th June 2011, 11:08 AM   #1758
Phaedras is offline Phaedras  Denmark
Phaedras's Avatar
Thanks in advance
1. Absolutely, with a 10w panel and no clouds you'll be charging the batteries fine even at full volume!
2. No problems!
3. Nope its not necessary.
Old 12th June 2011, 11:11 AM   #1759
Phaedras's Avatar
Its hard to mathematically calculate what sounds best to your ear
Resistors cost less to nothing, so its no problem trying different resistances.. Trying different values and listening to the results is better than trying to calculate
Old 12th June 2011, 11:24 AM   #1760
Of course this is what you could do. But I'm looking for an easier solution than trying out 10 different values. That's a lot of work compared to just putting some numbers in a calculator and then getting the right answer.
But I guess you're right - sound is hard to calculate precisely.
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
