The Boominator - another stab at the ultimate party machine - Page 95 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th March 2011, 09:43 AM   #941
rubennn is offline rubennn  Denmark
Yeah that's cool. Makes it look pro
I'll think about the masonite board. I could just make a circle of it and glue it on the inside. And then put a sealing gasket on top of that to fit between the grill and the masonite. Thanks for the idea Saturnus.
Old 26th March 2011, 10:00 AM   #942
Saturnus's Avatar
There's also the option just to cut strips out and fit around the cut out, and trim away what isn't needed. You could also do the same with 4mm acryllic sheets and mount LEDs in those strips so you'd have for example a running LED light show on the rim of the woofer.
Think of obstacles as possibilities for new ideas.
Old 26th March 2011, 11:25 AM   #943
Phaedras's Avatar
Originally Posted by Saturnus View Post
The most natural thing would be to make it longer though. However, it shouldn't be too hard to find a sealing band that compressed makes about 5mm. Just ask for it in the local hardware store. If it's a huge problem you could also get some masonite board and mount that on the inside, and cut away what you don't need. Masonite board is typically 3.5-4mm thick.
And there's also a neat side effect of the deeper placement of the driver in that if you mount the grills directly on the driver then with the deeper placement the tip of the grill doesn't protrude farther out than the front which in my opinion is more appealing aesthetically.
Ofcourse, longer would do just aswell..
OR - you could buy 3-5mm plexiglass and mount LED's around the edge for imba light effect
j/k - masonite sound like a nice solution..
Old 26th March 2011, 11:27 AM   #944
Phaedras's Avatar
lol, I didn't even see you had posted that.. hahahahaha..
Old 26th March 2011, 04:34 PM   #945
Hey guys.
I have been reading this topic since 10 o'clock this morning and finally reached to the present. To introduce myself: I am building this years roskilde boombox. I must say you guys have covered ALOT in this 95 page thread. Thanks alot for sharing all this valuable information so people like me can create the best possible gear for roskilde festival.
i have decided to go with saturnus' boominator and the bipolar design with the p.audio HP10w speakers.
#1) the first problem i ran in to is the tweeters. the HP100 are ofcourse not produced anymore so i tried to find the other ones saturnus recommended, the CTR KSN1001A. The problem is that i cant find a reseller who will ship it to Denmark. can anyone help me there?
2#) The next problem is about the amp. i have heard so much good things about the amp6basic, and i believe i have the skills to put it together, but is there any way to regulate the volume on the board without having to install an external volume control? the concern i have is if the volume is to high and some drunk idiot from my camp will turn his ipod up to load and ruin something? also, would you guys recommend a form of casing for the amp? alot talked about getting a alluminium casing, but i did not hear anyone who actually did it? is it a must?
3#) i didn't understand the issue with the modified PH10w measurements. Is the boominator mark II skechup made after thoose? (i will be using the measurements from there) i dont want to end up with the drivers not touching.
Besides that i think i am ready to order all the parts needed for this little project.
One last concern is that i have a car battery just lying around. Would it be possible to have it in our camp and hook it up in parallel with the other batteries for the extra juice (in the case that i'm not buying a solar panel)?
thanks for the good read and i am looking forward to keeping you posted on my working progress!
Daniel
Old 26th March 2011, 05:29 PM   #946
Saturnus's Avatar
1. The CTR KSN1001A appearantly has also gone out of production so all that is left is the identical CTR KSN1005 which unfortunately has the mounting flange on the front instead. Or naturally one of the copies of CTR KSN1001A.
2. The amplifier chip used in amp6basic have protection circuit built in so it shuts down long before any potential damage would occur. It self reset after a few seconds. A suitable casing would be something like this: Aluminium Enclosure 121,1x66x39,3 | HA1590N1 - Elektronik Lavpris ApS, it has the exact width of the electronics compartment, the length is the exact length between the venting holes. All dimension are also exactly the same as the recommended rechager, so you can mount the recharger between the venting holes on side, and the amp on the other, and have the batteries in the middle.
3. You might get HP10Ws from the old batch. You never know. In case it's the new ones just look for the solution suggestions posted.
Just like when you jump start a car you should make sure that you use very thick cables as the inrush current could be quite high. And possibly too high for the SLAs handle. You can get a SLA recharger that can run on batteries though.
EDIT: Btw, I've actually found the Chinese factory that made the original HP100 piezos. And they're willing to run a batch. I just have to order 1000 of them.
Old 26th March 2011, 05:55 PM   #947
Thanks for the fast response.
Well, i guess ill just dump the idea of using the car battery.
The amp6 just sounds to good to be true. Cant wait to get my hands on it.
im also having trouble finding the CTR KSN1005, though i managed to find the manufacturer (Piezo Source - your source for Piezo components), maybe they can help find a european reseller. Google has not helped me at all. Rather disappointing. Maybe you know of some resellers that googles algorithms wont show me?
Old 26th March 2011, 06:01 PM   #948
Saturnus's Avatar
Sadly no, can help you with resellers. I just happened to have some lying around because of a different project I was doing about 15 years ago.
Old 27th March 2011, 10:47 AM   #949
Say you are gonna order a 1000. What's it gonna cost? I guess when you're buying directly from the factory (and in china) it's gonna be pretty cheap for each piezo.
For a thousand from a danish reseller you'd have to pay around 70.000-80.000 DKK (but I would then again guess that a hefty discount deal could be made )
Damn... I love theoretical thinkning haha...
Old 27th March 2011, 03:42 PM   #950
Saturnus's Avatar
They were actually only $1.20 each if I bought 1000.
Copyright 1999-2017 diyAudio
