The Boominator - another stab at the ultimate party machine - Page 481 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 24th March 2014, 05:35 PM   #4801
Originally Posted by woytek View Post
Saturnus, any chance you got the full plans ready? I'm ready to build!
What're yer lookin for?
Plans are already there in Sketchup and PDF.
Old 24th March 2014, 05:41 PM   #4802
woytek is offline woytek  Netherlands
I would like to know the details of the design! I will be making my own enclosure so I don't need the drawings. I'm mainly interested in the crossover/woofer cap/details on the used BMS/etc.
Old 24th March 2014, 05:51 PM   #4803
WesleyK is offline WesleyK  Netherlands
PDF? Yep I'm also interested in the filter design.
Old 24th March 2014, 05:51 PM   #4804
Ahh yeah I see!...we'd all like that info!!
Old 24th March 2014, 06:53 PM   #4805
Haha, everyone's anxiously waiting for the full plans!
Me as well, I catch myself checking DIYAudio more often than normal...
Even though I'm not going to build a new mini immediately, it will have to wait until summer for me
Old 24th March 2014, 07:20 PM   #4806
bearberry's Avatar
Originally Posted by WesleyK View Post
I have added the set to the shop, in your cart you'll be able to select your country, to calculate the shipping costs. Also keep in mind that the VAT will disappear for customers outside the US after logging in. Will add more product information later on .
Thank you.
Old 25th March 2014, 10:01 PM   #4807
Saturnus, the cutout for the SP60 should be 98mm instead of the 96mm in the Sketchup file.
Old 26th March 2014, 06:15 PM   #4808
I have two amp6 basics that I ended up not using on another project. Would i be able to use both amps in the full sized bomminator? I planned on making the center compartment a bit bigger to accomodate 2 - 12v 15ah SLA batteries and run one to each amp. Would someone be able to help me with the wiring, as all the schematics in the thread are for 2 channels instead of four. I will be using the Goldwoods and the Original Motorla/KSN1001A. Thanks
Old 27th March 2014, 12:14 PM   #4809
One 30ah with the amps in parallel seems a better option to me. Try to get 4 ohms woofers, otherwise it won't make much difference with two woofers in parallel on one amp.
The Boominator Micro laser cutting file is coming along nice:
It doesn't fit on one sheet as you see. Total surface is +/- 0.35 m2. With birch plywood the total cost would be under 10 dollars. That's real cheap .
Saturnus, tweeter cutouts in Sketchup are 33mm instead of the 33.5mm Dayton suggests. Seems like it will be a precise fit so it wouldn't hurt to take the exact dimensions right?
And of course the file has to be converted to vector lines but otherwise it won't be visible
Old 27th March 2014, 12:41 PM   #4810
Saturnus's Avatar
I'd hold on with making a Boominator MINI/MICRO right now. There'll be a few changes coming.
Copyright 1999-2017 diyAudio
