The Boominator - another stab at the ultimate party machine - Page 325 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th September 2012, 08:17 PM   #3241
Here the 12v amp runs off the battery to the left and the 24v amp runs off both batteries in series. But i would like to run the 12v amp off both batteries in parallel, is this possible?
http://sphotos-e.ak.fbcdn.net/hphoto...70300917_n.jpg
Old 17th September 2012, 09:44 PM   #3242
danielwritesbac's Avatar
Not enough contacts on that switch to both rearrange the batteries and cycle power on two amplifiers. Tried it several times and ended up leaving one of the amplifiers on. It had to be the 24v amplifier because of voltage tolerance.
Added to the 12v amp:
DC-DC Buck Step-Down Converter 8-40V to 3-30V 8A Switching Power Supply Module | eBay
There's probably other ways to step down the 24v for running the 12v amp--just make sure the efficiency ratings are in the 90%'s so you don't get much waste heat from your converter.
Edit:
Maybe it would make more sense to use just 24v amplifiers?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 17th September 2012, 10:41 PM   #3243
It would be cool to use just the TK2050 alone, but i have heard it eats power..
But wouldn't this work? The 12v wouldn't be parallel, but just run off one battery.
Old 18th September 2012, 03:12 AM   #3244
I couldn't see your attached photo.
The switch can be arranged so that only one amplifier is on.
Unfortunately, the small signal line has ALSO connected the ground of the RCA jacks together. oops! Now you have a ground loop. So, set both amplifiers with the RCA jacks (input edges of the boards) touching and run a unified ground at that spot. When there is only 1 ground, then there's no ground loop.
For for charging, the 24v amp (maxes at 40v) can withstand the charger, but the 12v amp (max 14) cannot. So, have your switch simultaneously turn on both the charger and 24v amp simultaneously, and likewise the charger is disconnected if the 12v amp is on. The arrangement shown uses a ~24v CCS charger for charging both batteries simultaneously.
Old 18th September 2012, 03:27 AM   #3245
Or, for much lighter weight, try boosting the Muse TA2020 with the ClipNipper and solar panels to help keep the voltage up. Then you don't need the 24v amp at all.
P.S.
Muse TA2020 if 4 woofers
Muse TA2021 if 2 woofers
Old 18th September 2012, 12:08 PM   #3246
Can you see this photo?
I dont quite understand what your saying about the RCA jacks?
The batteries will be easily removable and charged externally, so that shouldn't be a problem. Then it can play 12v music at Roskilde festival, while i charge the other battery at my work
But cool idea, might use it, thanks
I have already bought 2 amps, would like to see if i can get something out of them, before investing in a 3rd...
EDIT: I got the switch the wrong way around in the diagram.
Old 18th September 2012, 02:08 PM   #3247
Saturnus's Avatar
You cannot have 2 amps connected to the speakers at the same time. Period.
Remember there's output filters in these amps, these will affect the impedance and frequency response of the system.
Old 19th September 2012, 05:43 AM   #3248
Aha! Just buy a 12v battery and attach it to the 12v amp.
Attach your 24v battery to the 24v amp.
Now, you can remove amp+battery as a swap-able unit.
Both amplifiers aren't present simultaneously.
P.S.
Use the dpdt switch to protect your 12v amp, block overvolting from charger, via preventing charge-while-run.
Old 19th September 2012, 01:55 PM   #3249
Ok...
I remember reading about someone building a boominator with 2 amps earlier in this thread. If i recall correctly it was someone from Camp Fri Ost, but i may be mistaken. Maybe i should just stick to the 12v amp, and use the 24v for a future project.
Nice out of the box idea, but it will cost me a battery more, and half the battery life in 12v mode. :/
Old 19th September 2012, 02:38 PM   #3250
Saturnus's Avatar
Ok...
Yes. They have 2 different amps. And they change between them. They cannot be connected at the same time.
Copyright 1999-2017 diyAudio
