| Class D Switching Power Amplifiers and Power D/A conversion |
#2911 |
In my opponion you should get another battery to solve this.. One of the points in having the class D amplifier is to have a very efficient power amplifier.. If you add a converter you will introduce losses and even though they state that they are >90% efficient this will foronly be the matter for some given operating point (problably at maximum capacity). During some other operating points the efficiency will for sure be lower. If you by any means have the possibility to add another battery in series, i would go for that :P
#2912 |
Ok, and then switch between running in series and parallel (12/24V) i guess?
But what about the amps? Do you have any recommendations? |
#2913 | ||
#2914 |
Since the TA2050 is not efficient, then why not shop for class D amplifiers?
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#2915 |
Hi guys, I've got a watt/ampere meter and would like to build it into my boominator with an on/off/on switch between 2 functions:
a) See the power consumption at a volume, so I can regulate the volume to lower power consumption if needed. b) See how many amps the solar panels are delivering. Unfortunately I'm having issues figuring out the switch wiring. Almost had a little fire today when I created a short. ![]() So basically I'd like some help on how to wire it? I know it's probably asking a lot, but maybe someone can find the time to help me out?
#2916 | |
Yes, it will deliver a constant 24v. |
#2917 |
Thank you for the suggestions, but I am just perplexed by the fact that my boominator seems to be playing at a much lower volume than others despite the fact that everything seems to be in order. If its possible to fix it without soldering that is my prefferable choice (I haven't read about anyone else soldering on their Muse TA2020). If not, I'll consider your options.
#2918 |
I think the first thing to try is to see if the amp is somehow broken. Ie. test it with another amp.
#2919 |
I just tried and it is a lot louder with my regular amp. Maybe I should just try buying a new Ta2020.
#2920 |
