The Boominator - another stab at the ultimate party machine - Page 278 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th May 2012, 10:10 PM   #2771
Why not build with HP-12W, just make the box a little bigger...
They have an extra DB in sens...
And dont put the magnets directly to eachouther, it will not give an extra sens.
have some centimeter between them.
Old 10th May 2012, 10:12 PM   #2772
Originally Posted by LukasL View Post
Hey folks!
I am having a bit trouble finding the right resistors.
Can I use a 47 ohm, 2W carbon film resistor with the monacor MPT-001?
10ps Japan RM (RMG) resistor carbon film audio grade 2W 47ohm|eBay
Any resistor between 12-150ohms will be fine.
2W is sufficent.
Old 10th May 2012, 11:02 PM   #2773
Hi folks,
We want to up the sound quality in our boominator and use PHT-407N tweeters with a crossover, but in order to save money on crossovers is it possible to wire the 4 x PHT-407N on the same channel? I've taken a look at some examples of series/parallel wiring, but i'm not sure I understand it fully.
So is the following wiring possible and recommended if we use Monacor's DN2618(http://www.monacor.dk/produkter/hoej.../vnr/122260/):
Or should we just go for one more crossover?
Old 11th May 2012, 06:32 AM   #2774
Saturnus's Avatar
Another cross over. Tweeters in series and woofers in parallel.
I'm also wondering how you could even think it would work?
Old 11th May 2012, 08:33 AM   #2775
I bave been wondering for a while if i have cut the bafflehole to small.
Its 22cm wide as in the sketchup file.
I havent found any good picture of how it is attached.
So I wonder if Sealing gasket will solve that problem or if I must make the hole bigger?
Old 11th May 2012, 08:43 AM   #2776
rubennn is offline rubennn  Denmark
The 22 cm is correct. You have to round the edges of your cut with a router (or another suitable tool) for the grill to fit. Remember that the speaker+grill is going on the inside of the enclosure. They should be glued together with strong glue (e.g. two-component glue).
Take a look at Phaedras' boominator:
Wohoo...Boominator 2012
Old 11th May 2012, 08:49 AM   #2777
I was testing the AMP6 substitute, the MKII TA2024 amplifier, yesterday with some 8 ohm speakers connected. I'm pretty impressed with the output levels.
But I noticed that the chip got a little hot, even at very low volumes. I haven't had time for testing outside at max. volume for a longer period of time, but does the chip usually get really hot?
Is a heatsink needed? I mean... Afterall it's only 6 W in peaks at full volume with 8 ohm speakers.
Old 11th May 2012, 09:52 AM   #2778
Correction: 10 W in peaks at max. volume. in 8 ohm.
Old 11th May 2012, 10:57 AM   #2779
@Saturnus: That just goes to show how lost I am...
Anyhow, i thought of a new idea. Building a half boominator with the ability to connect the second channel to a bass cabinet so we can utilize our HP12Ws.
And if i understand it correctly (according to Speaker Box Enclosure Designer / Calculator) then the following is close to ideal measures for a sealed box(Double the size for two drivers off course) at QTC 1 (Or should it be 1.1)?
Old 11th May 2012, 11:22 AM   #2780
Thank you! Yep, I knew that. Just some painting to do now...
I've read that some take off the rubber from the grill and some let them be, so what is the best way?
Copyright 1999-2017 diyAudio
