The Boominator - another stab at the ultimate party machine - Page 226 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 22nd August 2011, 09:12 PM   #2251
Saturnus's Avatar
Originally Posted by osny View Post
The speaker is broken, or it is possible to fix?
Technically yes, but it requires sending it to a workshop that can fix it, and it will certainly be more expensive than a new driver.
Old 22nd August 2011, 09:56 PM   #2252
osny is offline osny  Sweden
Too bad ist a brand new
Old 23rd August 2011, 07:05 AM   #2253
Saturnus's Avatar
Then why don't you contact the dealer?
Old 23rd August 2011, 09:33 AM   #2254
Import from USA, I don't feel like waiting for a new one, and ofc I would have to pay for it..
Old 23rd August 2011, 10:38 AM   #2255
Falken is offline Falken  Sweden
Hi!
Finally the woofers HP-10W arrived from Ljudia
( cancel order from Pluselektronik )
Mikael
Old 23rd August 2011, 11:10 AM   #2256
Saturnus's Avatar
Even in the States they have consumer protection laws. I'm not completely sure but if something is broken on arrival and it's not due to delivery, they have to replace it free of charge if it's returned to them. If it's during delivery it got broken then it's the delivery company's insurance that has to cover it.
Old 23rd August 2011, 12:24 PM   #2257
This is the right level for direct connection to a very low output device like an iPod or most smart phones. It shouldn't need a step-up trafo.
but won't the step-up still up the volume?
and if so - will it create distortion when put on max?
Old 23rd August 2011, 12:43 PM   #2258
Saturnus's Avatar
Yes, on both count. Actually it'll just make the chip shut-down at maximum volume.
Old 23rd August 2011, 01:16 PM   #2259
fine - no step-up then
Old 23rd August 2011, 03:06 PM   #2260
just because nothing really happens at the roskilde forum (guess I should have seen that one coming) i decided to copy-paste my note, because i really need an answer
"So we've decided to build half a boominator (with a variant in the piezo's). Since one of the demands were that the box could last the entire week (or at least on one or two recharges), I have to make sure my calculations are right. Previosly in the thread you, saturnus, calculated it for someone, with the exact amp that we're using, with these numbers.
On 4 ohm the amp draws 350 mA on max volume, and if we use a traction batteri, with 22 Ah (the lowest we can go, without it being either too expensive or too small an amount)we would be able to hold for
22*2/0,35 = 125 hours
you also wrote that with 8 ohm it'll be twice as long, in other words about 250 hours which equals to about ten days are my calcuations correct or am I doing something wrong
the variant in piezo's are one of these two models
QLM-1005 - Ljudia - Multimedia Hemelektronik Karaoke PA anläggning DJ utrustning Ljus utrustning
Rila SA38 Piezo - Ljudia - Multimedia Hemelektronik Karaoke PA anläggning DJ utrustning Ljus utrustning
Can they be used ? "
Copyright ©1999-2017 diyAudio
