The Boominator - another stab at the ultimate party machine - Page 168 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th May 2011, 10:31 PM   #1671
Saturnus's Avatar
A round one on each side then.
(Note: I've actually never built a Halfinator)
Old 27th May 2011, 07:23 AM   #1672
rubennn is offline rubennn  Denmark
Originally Posted by 2byohm View Post
Woops my bad. I meant if Rubennn could send me his dimentions of his Roskilde Boominator from 2010 that he has presented in his slideshow
Never commented on this and I'm sorry for that. There is a half boominator sketchup drawing of the thing. Search "half boominator" on google and you'll find it.
You need Google Sketchup to view it. You should also design your own electronics compartment as the one I made has cutouts for my electronics
Wohoo...Boominator 2012
Old 27th May 2011, 10:27 AM   #1673
I just bought these on/off switches at Elextra.dk and got them sent so I didn't get to ask the an employee in the physical shop how to connect these. But I thought that on/off switches had 2 poles and that you're supposed to solder the plus-wire to each pole. This switch however has 4 poles.
Do I just connect the the big poles (which is "ON") to the wire like illustrated or something different? I don't want to make something wrong when it comes to electronics
Old 27th May 2011, 10:38 AM   #1674
Saturnus's Avatar
It's just a double 2-pole. And it's a rocker switch, so it's not that hard to figure out. There's no connection between the two sides so what you're suggesting won't work.
You connect the plus from the battery to one of the poles on one side and plus to the amp on the other pole on the same side. It doesn't matter which goes where if they're just both on the same side.
You can then choose whether you want to do the same with minus just on e the other side. I would but you don't have to.
Old 27th May 2011, 10:46 AM   #1675
craler is offline craler  Sweden
craler's Avatar
Send a message via MSN to craler Send a message via Skype™ to craler
Does this look right? Is a vent length at 10,62cm feasible?
Old 27th May 2011, 06:43 PM   #1676
Hi
I have been reading this thread for a while now, and read all of it, and me and my camp think we know what to do.
We will not follow the boominator design, but we ordered a AMP6 Basic, which is currently under construction, the only thing we really need to figure out is which units to use in the box.
Our plan is to have 4 10" units and 4 piezo tweeters on one side. The reason for this is how we plan on using the box in the camp, which will be mounted on a cart from a Harald Nyborg.
But since the P.audio HP-10W is no where to come by now, and the Goldwood GW-1058 is only sold in USA, which we won't attempt because of DK customs.
Do you have any other suggestions for units we can use in our setup?
Our budget is max 2400 for 10" units and tweeters, and we maybe thought of something like this?
Hartke 3-10XL8 XL 10 - Ljudia - Multimedia Hemelektronik Karaoke PA anläggning DJ utrustning Ljus utrustning
We know the festival is closing in, so we maybe cannot find the ideal units, but preferably something close and not to expensive.
In advance, thank you for your help.
Old 27th May 2011, 06:59 PM   #1677
Saturnus's Avatar
As I've said repeatedly. It is not a good idea to mount them on one side when the purpose is outdoors use. You will not get more output on the side "facing" the crowd and you will get worse performance.
Why not? Just buy them through shopUSA.com or myUS.com, they will handle the customs for you.
Old 27th May 2011, 07:08 PM   #1678
I missed the part about not getting more output on the side facing the crowd, but still.
Any recommendations regarding speakers, since we cannot get hold of the best suitable before Roskilde?
We know that we might not get ideal speakers, but we are okay with something that is atleast decent.
Otherwise we are just planning to look through the stores, and find some 10" PA speakers we think are good, like the ones I linked to before.
Further, we are planning to use two car batteries for power, and yes we know this not not ideal, but we can get them for free, and that helps out our budget ALOT.
Thanks for your help :-)
Saturnus:
We prefer to buy them through an DK or EU dealers, since none of us have ever used such services before, and we wan't to be 100% sure, that we have the speakerunits on time, and preferably atleast 1 week in advance.
This is also caused by the fact that the money spent on this project will be paid by the entire camp, which is why we wan't to be sure, that we have a working stereo when Roskilde starts.
Old 27th May 2011, 07:45 PM   #1679
Saturnus's Avatar
Well, technically you will get more output. But you have to filter it away.
Sound wraps around speakers as you know. Which is why you can hear bass behind a speaker but almost no high frequencies.
In a room the sound that is wrapped around the speaker is reflected by the walls so you get a linear response.
Outside where there are no walls to reflect the sound that sound is in principle lost. So in order to get a linear response you have to insert a filter that starts very low and filters away the appearant added output of mid and high range. Otherwise the sound will be very thin with lacking bass and exaggerated higher mid/high range.
By placing speakers on both sides the wrap around effect works on both sides so it in principle works like the walls in a room and thereby giving a linear response from both sides without the need to filter away high frequencies.
Old 27th May 2011, 08:08 PM   #1680
That makes perfect sense, never thought of it that way.
Will try to convince me camp buddies, so we can build it in the same way as the boominator.
But that still leaves the unit question.
We would use HP-10W, if we could get our hands on them, but people are just not willing to try and order them from the US, since we cannot be sure about shipping time and such.
So, is there no real recommendations for units, instead of the two mentioned?
If not, we will just try to do our best in finding replacements somewhere in DK or EU, that is within our budget, but i would prefer a recommendation from here, since it seems that you guys know what you are talking about.
Copyright ©1999-2017 diyAudio
