| Class D Switching Power Amplifiers and Power D/A conversion |
#1611 | |
If it's embedded there's nothing you can do but if the miscolouring is on the surface you can try heating it with a hair dryer and see if it doesn't go away. Last edited by Saturnus; 24th May 2011 at 08:32 AM. |
#1612 |
With the LED in the Lepai amp, can't you simply cut it off? It won't consume power then.
#1613 | |
#1614 |
I must admit I'm not a fan of the HP12W except for bass. Midrange performance isn't nearly as good, although I suppose it's "good enough" for many uses. There's also a nasty spike at 2KHz after which it rolls off. I'd normally recommend a cross over for it at max 800Hz and preferably lower.
#1615 |
Hey guys. I have been reading your posts on this site and the Roskilde-Forum site about building a Boominator
Me and the rest of people in my camp are new to this business and i was wondering if i could get some help about making a boominator. First i would like to ask Picarro if you could give me the dimentions for your Roskilde Boominator 2010. I looked at your slideshows, and it seems alot like the one im going to build. Second im thinking about buying these parts:I bought an Amp6basic already, so i need speaker units and accesories for the boominator: 2x MPT-005 Piezo-Hochtöner IMG STAGE LINE HP-10W is out of stock in Europe so i have been thinking about buying these: 2x SPA-10PA PA-Tiefmitteltöner, 220WMAX, 8Ohm IMG STAGE LINE That's my starting point and atm, im pretty lost in how to make a boominator, and which parts i need beside the speaker units and amplifier. Would be really nice if you could give me some hints and advice. Regards Tobias |
#1616 |
Woops my bad. I meant if Rubennn could send me his dimentions of his Roskilde Boominator from 2010 that he has presented in his slideshow
#1617 | |
#1618 |
#1619 |
Thx mate, that's going to help me, but I have been reading alot of these threads about a boominator, but you have to consider many parametres when you build it, and that's what freaks me a bit out. As an example, we bought the Amp6basic, and now i have read on 41hz.com forum that the model we bought back in april has some defects... What im most confused about is: which cables do i have to buy to connect bass to tweeters, and so on. But also how i can control volume and turn my amplifier on/off, because i bought it without a box.
#1620 | |
Saturnus, how would you describe the sound of THE Boominator (built as intended)? And another question: Wich one of your Boominators are you gonna bring to Roskilde? Looking forward to hear a Boominator with the right equipment. I hope that you feel proud for creating this monster-thread :P I've been following it for over one year. Fun with the quadrupled demand of HP-10w's. The dealers must be scratching their heads. Greetings from Sweden and see you at Roskilde ![]() Daniel |
