The Boominator - another stab at the ultimate party machine - Page 132 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th May 2011, 11:20 AM   #1311
ThokN is offline ThokN  Denmark
Alright, but couldn't it be a good thing to place one tweeter in the middle as they have done? Or do you think a tweeter on each side sounds better? Or maybe louder?
Old 4th May 2011, 11:25 AM   #1312
Saturnus's Avatar
The principle is meant to have a tweeter on each side, or the drivers on those sides being full-range. What the top/center, whatever mounted tweeter does is make a narrow wave cancellation beam of high frequencies so that in a room you'll hear reverberant sound over direct sound. The center tweeter has no (positive) effect outdoors.
Old 4th May 2011, 11:35 AM   #1313
rubennn is offline rubennn  Denmark
I just have to say that I made half a boominator for a friend having him pay the materials. Once again I was a bit stressed with finishing it before the 1st of May on his request. But the sound... of what I heard (it was just a quick test)... was pretty good. Though it probably plays less loud that the original boominator, it still plays surprisingly loud for people not having heard it before - and that was my friend
Unfortunately, I haven't got all the pictures of the finished project because of the fact that it needed to be done before May 1st. I will ask my friend for some pictures and post them here soon. It's not a perfect build, a lot of visual flaws are present but I definately like that it has the same sound quality, less weight and that it doesn't take up much space.
If there's one thing I would like to do differently, it is to use a tube as port next time and place it in the front/back of the half boominator to be able to sit on it while the side that originally has the port is facing the ground. Portability also means a lot to me.
Have a good one
Old 4th May 2011, 11:42 AM   #1314
Saturnus's Avatar
Have a good one
Why not just put it on the side while playing like a full size Boominator? Or is it more convenient with the roughly 50cm height compared to 30cm?
Old 4th May 2011, 11:53 AM   #1315
Hallo everybody.
I'm about to build my new boomblaster for Roskilde 11'
I have thougt about makeing a "double boominator" with 8 hp-10w, 8 horn bubble tweetters, 2 amp6basics and of course a twice as big cabinet.
But I'm not sure about how much more sound i get in proportion to I double up all the parts, and if it is possible to use two amp6 in one system at all, I have just thought about using a jack splitter like this:
Itech Minijack splitter kabel 0,2 meter
Are there any other considerations i should have in mind?
Jonas
Old 4th May 2011, 11:57 AM   #1316
Yeah I was thinking that it would be more convenient. Also you can only sit one on the boombox when using it the way I described (which I dunno is a good or a bad thing), but then you just tilt it to the other side.
Also it has the advantage when wanting to make a lid like this drawing:
Old 4th May 2011, 11:59 AM   #1317
Originally Posted by jonasvj View Post
Hallo everybody.
Jonas
Maybe you sould just consider making a regular boominator design with a more powerful amp, like the AMP9 (if it's more output you seek)
EDIT: Or maybe 2 seperate boominators running on the same signal.
Old 4th May 2011, 12:04 PM   #1318
Saturnus's Avatar
Oh, you edited it. I was about to say the same thing. Build 2 separate Boominators. It'll be easier to transport, and you have a lot more options for placement. And if you're going to the park or beach or somewhere not being Roskilde then just having to haul one Boominator will be a lot easier to manage.
EDIT: in any case, 2 Boominators will be twice as loud as one. That's a no-brainer. A Boominator with a 24V amp is also about twice as loud as one running on a 12V amp. So if you really want it loud then 2 Boominators on one 24V amp would be insanely loud. In fact one amp9b could run both.
You should note that a standard Boominator already plays louder in average SPL at 2 meter distance than what Roskilde Festival is allowed to have as maximum average SPL in front of the stages.
Old 4th May 2011, 12:06 PM   #1319
Saturnus's Avatar
I'd probably make sure to have the piezos in the top instead of the bottom.
Old 4th May 2011, 04:35 PM   #1320
Nahaz is offline Nahaz  Sweden
Its time to close the lid, all the connections are made, secured and tested.
I will seal the lid with silicone (the rest of the box is glued) to be able to open it in the future.
Saturnus: What about dampening material, do I put anything in or let the box be "naked" on the inside?
Copyright 1999-2017 diyAudio
