Go Back   Home > Forums > Amplifiers > Class D
Old 12th June 2008, 09:54 AM   #121
Sjanten is offline Sjanten  Denmark
Hi all
Saturnus, I have great respect for your workmanship, it looks great!
Janoch, as Saturnus said, horns would not work, not that they're not great in many ways, but they do not come in small packages!
I've build some designed by Bill Fitzmaurice that we use for the festival, and with a sensitivity at approx. 110dB they do give a lot af bang for the buck!
But as you can see in the pic, the total package is 180 x 170 x 80 cm total, and weighs 400 kg...
KILOWATTGRUPPEN.DK
Old 12th June 2008, 12:56 PM   #122
Saturnus's Avatar
Originally posted by janoch23
Those HP-10W's seem to be way ahead of the alternatives for the price (~30 euros ea). I've been searching high and low for something smaller with similiar sensitivity at a decent price (say <€150 for 4), but to no avail.
That's the real problem, I have yet to find anything that is even remotely as good as an alternative to the HP-10W. I've used them for various projects for many years. And for the price they offer exceptional quality. I've tried many other, and much more expensive drivers, but I constantly return to this one for it's natural sound and exceptional voice detail.
Like most PA drivers they don't like very low volume levels but being used outside where there's lots of background noise that's not a problem. They also don't like high excursions and start to sound really bad when forced to do that but cutting out the extreme low end and the limited power output of the amp6basic makes sure that doesn't happen either.
Put simply, I can wholeheartedly recommend the HP-10W, for this specific purpose they're in a league of their own.
Old 12th June 2008, 03:27 PM   #123
2 x HP10W is too big and heavy. And you're right, there are no cheap mono Class D amps.
I don't know why I didn't notice these from Hifikit before: RILA BW818 for just €20 ea. However they sound "too cheap" and I don't know enough about speakers to draw conclusions from the T/S numbers.
8" Paper cone, impedance 8 Ohm
Freq range 55-4000 Hz
200 unspecified watts
Sens: 94 dB/SPL
Resonance: 55 hz
Vas: 392 L
Qts: 0.31
Weight: 1.5 Kg
Nothing else is specified! Other threads say RILA specs are not to be trusted either.
Anyway, 97 db at 3 kg / €40 sound like it would suit my needs. Could these work in a boombox 2 x 8" ?
Next step up is >$100 for 2x8".
Old 13th June 2008, 12:17 PM   #124
Saturnus's Avatar
They might work
At that price it can't hurt to buy a couple and test it, if they're no good ... no great loss.
Cabinet size I would aim for with 4 of these would be 24x24x60cm
But this one might actually be better, and it's 6½" and cheaper to boot ... http://www.hifikit.org/index.php?id=284
Old 14th June 2008, 04:02 PM   #125
Default bipolar?
I don´t realy understand this with bipolar design and in what order you connect wires, rigtht/left, +/- to the amp? How does it work and how do you calculate cabinet size for a bipolar design.
I have been following this tread from the start with most excitement. And of course I am also into building lightweigt BIG sound.
My latest idea is to put one B&C 10HPL 64 in a 20l BR together with a compression driver. Mono but loud.
Old 18th June 2008, 12:56 PM   #126
v-bro is offline v-bro  Netherlands
v-bro's Avatar
it's not a Boominator, but I just thought it would be nice to show you guys my latest creation:
http://41hz.com/Forums/topic.asp?TOPIC_ID=1917
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 18th June 2008, 01:41 PM   #127
NED 209 is offline NED 209  Ireland
NED 209's Avatar
gorgeous Vincent. im gagging for one of your macaronies... i wonder how international airports would view them though.. as a suspicious looking device?
Saturnus one thing thats puzzling me bout the boominator - amp six, a two channel amp, is running all 8 drivers? could you explain how this is done please?
Old 18th June 2008, 01:52 PM   #128
v-bro's Avatar
Thanks Brian! I have taken the Macaroni to England and back by airplane, there was just one question about what it is. I explained and it was OK.
I guess it depends on the people checking it... I can imagine it can give trouble, but I took the risk...
I think Saturnus has series/parallel connected a few of the drivers....
Old 18th June 2008, 02:36 PM   #129
Saturnus's Avatar
Hmmm ... there's 4 woofers and 4 tweeter in each essentially making it 4 speakers. The 2 in each volume is paralleled to make it 4 Ohm. Pretty standard.
V-bro, very nice work as usual from you. But why the amp11 this time?
Old 18th June 2008, 03:12 PM   #130
v-bro's Avatar
thanks man!
Sorry to come barging in your thread this way, but I thought it would be interesting for the readers here...
AMP11 is an excellent amp, it has lots of headroom and extremely wide voltage range (I modded it to work from 9Vdc to 32Vdc!) extremely low distortion....lots of space and holes for any kind of input cap....
It is also very nice that it's a mono module and it's single supply, so easy to operate on a battery. I also like the black PCB and all modules I made worked right away!
AND there's a new chip coming up that works up to 50V! It is pin compatible and when you only change a few caps on the AMP11 it can output up to ~200W! More about that later...
Short: AMP11 is one of my favorites for sure!!
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
barbfa, Arty
Page generated in 0.11530 seconds (66.91% PHP - 33.09% MySQL) with 11 queries
