diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Best value T Amp in UK ? (http://www.diyaudio.com/forums/class-d/104388-best-value-t-amp-uk.html)
audio1st 29th June 2007 08:01 PM
How is this for a bargain, and NXT speakers..http://www.richersounds.com/showprod...id=KENS-SX2000
PS, If your in the VIP club it's only 20!
audio1st 29th June 2007 08:03 PM
2 Attachment(s)
The inside.
audio1st 29th June 2007 08:05 PM
2 Attachment(s)
Close up.
audio1st 29th June 2007 08:07 PM
2 Attachment(s)
And this is included..:D :D
Sonusthree 30th June 2007 01:21 AM
How does it sound?
I saw those and wondered if you'd need to buy two to create a decent stereo image.
audio1st 30th June 2007 08:54 AM
Originally posted by Sonusthree
How does it sound?
Yes, as is, it is definitely not a wide sound stage and bass is light. I may add some speaker sockets and see what comes out.
Puffin 30th June 2007 11:12 AM
Audio1st. I assume that when you open the thing up that it is obvious where the speaker connections should go ?
I am interested to hear if it sounds any good with a normal system. Is it tweakable ? (lots of SMD's !)
robert1325 30th June 2007 12:28 PM
What T-chip is in there? 2024?
Puffin 30th June 2007 01:12 PM
Yes 2024 as the Sonic Impact.
audio1st 30th June 2007 01:25 PM
2 Attachment(s)
The other side is even worse for SMD's, (push button volume control)!.
But the basic Amp part looks very tidy..
As is, the input Cap value is 0.68uf. Bridge the 1uf will sort that out.
obviously to get the best out of it you would have to use your own volume control and come in at the 2.2uf cap.
the chip is the 2024..
Copyright 1999-2017 diyAudio
