Self oscillating fun - Page 6 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th November 2007, 08:24 AM   #51
h_a is offline h_a  Europe
h_a's Avatar
@Eva: would you please contact me via email? I would be very interested in your opinion on 1 or 2 things but I cannot reach you via email. Thank you very much!
All the best, Hannes
High Octane phono preamp Wiki
Old 8th November 2007, 08:30 AM   #52
Ouroboros's Avatar
What! Using an expensive E96 range 221 Ohm insread of a low-cost E12 range 220 Ohm?
Bizarre!
Old 8th November 2007, 11:24 AM   #53
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I got the mails, but I don't have the simple and clear answers that you are expecting to your questions. Sorry.
I use to feel like the small child in The Emperor's New Clothes tale
Old 9th November 2007, 09:06 AM   #54
h_a's Avatar
@Eva: I see! Thank you very much! All the best, Hannes
Old 5th February 2008, 08:01 AM   #55
Eva's Avatar
Bizarre!
Who? I swear I didn't
UPDATE:
I have been working in other similar but higher priority projects for the past two months.
However, now I have got plenty of SMD chip capacitors to cut parasitistic inductance and solve the ringing problem, including luxury stuff like 220nF 200V, 100nF 500V, and 220nF 630V (dual chip TDK which I manually split to get two 100nF). I have also developed a new magnetic snubber with much lower winding losses due to eddy currents, much lower shunt capacitance and no longer involving flyback peaks over 2KV. Furthermore, I have developed an active clamp circuit that recovers the energy from magnetic snubber leakage inductance too.
I will apply these new resources to this project as soon as I finish the higher priority stuff. I think that the future is quite promising, for example, with the new magnetic snubber and active clamp the switching frequency may be increased to 200Khz without too high losses.
Old 5th February 2008, 08:16 AM   #56
Bender.ru's Avatar
Hi Eva, it seems to be very interest.
btw, what kind of 220nF*620V chip capacitor do you use, who is manufacture? are they 10% precision or better?
Old 5th February 2008, 09:02 AM   #57
Eva's Avatar
Check the datasheet, TDK P/N is CKG45NX7R2J224M :
http://www.tdk.co.jp/tefe02/e415_ckg.pdf
I got them from RS-Amidata Spain. They were expensive but I needed something rated at 630V.
Old 5th February 2008, 09:17 AM   #58
IVX is offline IVX  Russian Federation
IVX's Avatar
Murata make it also (X7R .22/630 GRM55DR72J224KW01L), BTW, film caps SMD .22/630 are exist too.
Best regards,
E1.
Old 5th February 2008, 09:22 AM   #59
Bender.ru's Avatar
Eva, thank you for infomation.
Hi, Ivan! i've got that murata's GRM55DR72J224KW01L (~1000 in stock ), but they are 10% tolerance .
Old 5th February 2008, 09:23 AM   #60
Eva's Avatar
Why do you need tight tolerance?
I thought we were talking about supply deocupling capacitors
6j4 oscillating? Klimon Tubes / Valves 2 18th January 2008 09:32 PM
PSU oscillating apolon34 Power Supplies 3 24th June 2005 02:20 PM
oscillating...always oscillating WoulYaShassu Solid State 30 9th April 2004 05:31 PM
Copyright 1999-2017 diyAudio
