High voltage Class D
Old 17th June 2007, 04:56 AM   #11
ChocoHolic is offline ChocoHolic  Germany
Nonoise:
For PWM generation there are multiple possibilities out in the forum. Stroll around, find your taste and experiment without or with low voltage power stage first.
If you feel that this is to much work, search and copy a bullet prof design with similar drivers and then scale up.
eakerin:
...yes, the energy in the capacitance increases by U^2...
But your proposal for the output transformer is also not a simple solution. The transformer will also see the low frequency component, which is hidden in the PWM. So the size of such an output transformer will be similar to what we know from tube transformers. For 100W this is already some heavy piece...
High voltage Class DHide this!Advertise here!
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
