Go Back   Home > Forums > Amplifiers > Class D
Old 11th June 2007, 06:50 AM   #1
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
Default ClassD protoboard
Hi All
I've designed a small prototype-board to simplify bread-boarding with IR21XX-chips. The board should be made on 2 layer PCB and the bottom-layer should be a solid GND-plane.
You could use single-sided PCB's, but then it should be placed on a aluminium-plate. The side with holes are supposed to hold the output-fets and any voltage-regs' for the low-power circuitry.
All components are surface-mount.
The .jpg should be scaled so that the pad-spacing (center to center) is 2.54mm.
I know that the quality is not very good. I have a high-res pic at my desktop.
I will try to make some and show the results.
Fell free to use the PCB-layout to any non-commercial project.
Regards TroelsM
Need more time...
Old 21st June 2007, 10:54 AM   #2
TroelsM's Avatar
260 wievs and no comments?
Has anyone used my layout? What should be better?
Is it of any use?
Regards TroelsM
Need more time...
Bipolar Variable Power supply for protoboard jman 31 Power Supplies 10 24th March 2009 02:39 PM
Could somone please check my KC Protoboard? Bassivus Digital Source 22 19th June 2007 09:32 PM
classd.com domain name available elfling Class D 3 29th April 2007 02:40 PM
New to ClassD DarkOne Class D 2 24th September 2006 04:11 PM
GC VS classD etalon90 Chip Amps 0 3rd November 2004 05:29 PM
Page generated in 0.06704 seconds (64.39% PHP - 35.61% MySQL) with 11 queries
