| Class D Switching Power Amplifiers and Power D/A conversion |
Banned
What characteristics should I look for the PNP transistor in an active PNP turn-off circuit for driving large TO247 mosfets? It is intended to be after the IR211x driver output.
-I guess VCEmax around 25V is more than enough, as Vce=Vgs. -A high max. collector current (2 to 10 amps) is desired for really fast turn off, right? -What about Hfe min, transition frequency, etc? I want to run it at 350KHz approx. I have found some candidates such as : MJD2955 ZXTP2012ZTA MJD45H11TM Do you think they are suitable? Would you recommend any other part number? Thanks! |
#2 |
my favorite:
zetex fmmt717 , 10 A peak !!!! , sot23 , hfe > 200, 110Mhz |
#3 |
Don't the IR211x gate driver IC already have active gate turn off?
Also they can switch at 120ns..??? |
#4 |
A 2n3906 is enought! The peak to discharge a gate is about fews ns....Except if you use a tick trace on your PCB, IR2110 is enought to discharge it. The only draw back, is the dissipation. Here you need a PNP discharge help...
Fred |
#5 |
Banned
Well, I have seen some peak before turning on in the Vgs voltage that I don't like, it grows (up to 6-7V or more) as duty cycle is increased. I believe it can be due to reverse transfer capacitance turn on, so I think that a PNP turn off will help keeping the Vgs voltage down. Right?
I also want my IR2110 working more relaxed... |
#6 |
if you change the gate driver to ir2010 isnt easier?
#7 |
Hi! Why don't you use TC4422 and ADuM isolator close to GS for a few ns?
#8 |
Banned
Well, about IR2010, nice, but "only" 200V max. Vcc. A bit tight if you want +/-90V rails, isn't it?
Adding an optoisolator (or similar) and mosfet driver is a good idea, but I want to keep it as similar to the original design as possible, by the moment (using only IR2110). |
#9 |
Follower using it's good idea indeed, ir2110 almost have not chance to live, after the mosfet blew up, bc807/817 will have much more chance even. On the other hand, why you need 2A($2) driver, if followers in use anyway? So, you can get more reliability for less money.
Best regards, E1. |
#10 |
Banned
The idea is simply to update the existing design for faster turn-off, by the use of a typical active-turn off PNP transistor.
The turn-on is still driven by the IR2110, so you need 2A. This way the chip will work more relaxed, too, as it doesn't have to sink the high turn off current. |
| Output transformer matching to active device driving it | macrohenry | Solid State | 3 | 17th August 2007 07:51 AM |
| Full-turn/partial-turn pots | slowpogo | Parts | 1 | 12th January 2007 08:40 AM |
| MOSFETs (active rectification) in place of diodes in linear PSU | UnixMan | Power Supplies | 44 | 18th January 2006 07:45 PM |
| Paralleling large number of Mosfets. | danieljw | Solid State | 47 | 26th February 2005 06:43 AM |
| WTB: Large 50vdc caps and MOSFETS | RichardJones | Swap Meet | 4 | 30th May 2003 01:25 AM |
| Page generated in 0.11243 seconds (78.39% PHP - 21.61% MySQL) with 11 queries |
