Go Back   Home > Forums > Amplifiers > Class D
Old 21st May 2007, 12:55 PM   #1
Question amp that can handle 600 watts subs
im new at this site, and im not sure if this topic falls under Class D. I have a 15" kicker subs that i want to plug in to an amplifier so that i can run it at my room using 220v power plug.. i hope you guys can help me thanks.
Old 21st May 2007, 01:14 PM   #2
Pierre is offline Pierre  France
Banned
Hello, Slamdunk
Do you want to design the amplifier circuit and PSU yourself, or do you want an amplifier module and PSU?
Old 21st May 2007, 01:17 PM   #3
i cant design... how about a ready schematic and ill try to follow it will that work?
Old 21st May 2007, 01:24 PM   #4
Hartono is offline Hartono  Indonesia
yes you can, might be a bit hard though , have you made any amplifier kit before ? I think quite plenty is available in phillipine
Old 21st May 2007, 01:28 PM   #5
how about for beginners that wants to make an amp that will run 600 watts at 2ohms ... where can i find a schematics? or what do i need, i want to try making one... i never build an amp before
Old 21st May 2007, 03:29 PM   #6
600 watts at 2 ohm is pretty formidable project, especially if Class D. and switching supplies.
for beginner better not make anything larger than 100 watt first.
and using 2 ohm load you will waste a lot of power in the cable, connector resistance, etc, also the amp will have hard time driving it.
does the subwoofer have 2 x 4 ohm voice coil ?
better solution is to drive it in series to become 8 ohm.
or using 2 amplifier to drive each voice coil.
there are many schematic, the problem is , if not done correctly, and the amp/speaker is damaged........... well we wouldn't want that to happen right ?
do you have oscilloscope and multimeter ?
we can take it step by step here, I'm sure plenty of people here would have many suggestions.
anybody have simple amplifier plan for Slamdunk ??
Old 21st May 2007, 04:04 PM   #7
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I have modded P68 from www.sound.au.com with 50V rails and ten pairs of MJ15003/4 devices. can drive about 500wrms into 2ohms
Old 21st May 2007, 04:20 PM   #8
Thanks for the info djQUAN (lechon lechon lechon )
I'm having trouble accessing that page
I believe this is the same website with the same project :
http://sound.westhost.com/project68.htm
if you look down on the article..... down in the middle..... there's this red colored sentence that says :
DO NOT ATTEMPT THIS AMPLIFIER AS YOUR FIRST PROJECT
was it simple to build and measure for beginner ?
Old 21st May 2007, 04:46 PM   #9
that was because the amp deals with high power and high voltage supplies. the reader will build it at his/her own risk I won't be held responsible for whatever happens to him/her or what happens to the equipment.
Old 21st May 2007, 04:53 PM   #10
yes true
I would be very concerned if any beginner is making 600 watt amps.
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
Can we handle more zen? bertjan Pass Labs 10 31st July 2006 10:04 AM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Too hot to handle Panelhead Pass Labs 3 8th May 2003 12:10 AM
Page generated in 0.09928 seconds (75.80% PHP - 24.20% MySQL) with 10 queries
