Go Back   Home > Forums > Amplifiers > Class D
Old 20th May 2007, 01:46 AM   #1
Send a message via Yahoo to darw82
Default Re-building Crest Audio LT1000
Dear All,
I'm building LT1000 amplifier. When I take a look the schematic closer. I think I found an error. But I'm not sure.
Please see attached picture or you can download the schematic at
http://www.crestaudio.com/media/pdf/LT_Schematic.pdf
The sense resistor output votage (below low side FET) is negative, while the over current offset voltage is positive. How come this work?
Please tell me, is this an error?
Thank you
Old 20th May 2007, 01:56 AM   #2
Here is the board layout.
Old 20th May 2007, 05:15 AM   #3
Talking Re-building Crest Audio LT1000
do you have pcb file!
Old 20th May 2007, 08:15 AM   #4
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
On this resistor you get image of negative and posivit current, so both + and - lines are protected. I think there is no error.
I have is the same just without amp. But I do have sense resistor on both rails
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 20th May 2007, 08:31 AM   #5
Luka,
Are u sure this will work? I have simulate it using electronic workbench. It doesn't work.
But if this work. I'll build exactly same with the schematic.
Anyway, I also have a question regarding the power supply.
This amp will be use in car.
I seen many car amplifier, using open loop push pull power supply and without output inductor.
The question is,
1. which is better. open loop or closed loop?
2. Should I use output inductor in the power supply?
Thanks.
Old 20th May 2007, 08:47 AM   #6
luka's Avatar
Hi
Op amp is there to amplifie thevoltage drop on resistor, after that it is the sam I have. when overcurrent is detected, 555 is trigered and shuts down amp. I didn't realy check if this happens for both sides, but it sure does for lower side. If you are not sure you can make the same circuit for upper resistor and drive the same 555
electronic workbench is not good for testing, I have used multisim with is adv. electronic workbench.
1.) Don't know what would be better but I will go for closed loop, so that I can make solid rails without saging for power that I need.
2.)I had, but many don't. I don't know why not. Probably because they have open loop.
I FEEL SLOVENIA
Old 20th May 2007, 09:03 AM   #7
It will be more complicated if sense resistor placed in high side configuration. I'll need differential amplifier, such as INA168. But I try to build this overcurrent module only. So if this doesn't work. All I need to do is change it. not the whole amp.
By the way, I have attached super large picture of this board + the protel 2004 file on your email.
Thanks.
Old 20th May 2007, 09:11 AM   #8
luka's Avatar
Hi
Thank you very much. Please do let me know how it will work. Use "modules". One would be this overcurrent. So if something doesn't work you just make new one.
I FEEL SLOVENIA
Crest Audio 4801 PSU Capacitors tarka25 Solid State 3 23rd October 2008 05:15 PM
Crest Audio Schematics Needed and more? spirus Solid State 14 3rd April 2008 12:06 AM
crest audio power amplifier hienrich Solid State 7 18th January 2005 12:28 AM
need help building a 50 W audio amp! styoshi Solid State 0 23rd April 2004 06:24 AM
Page generated in 0.09223 seconds (75.17% PHP - 24.83% MySQL) with 11 queries
