| Class D Switching Power Amplifiers and Power D/A conversion |
#101 |
This is a picture of the Test Bed I am using for the Coupling Cap Test.
I have labeled the various caps on the test bed, and the major components external to the AMP6. Just above Vol (Volume Control) is the sleep toggle for the AMP6, which is not labeled.. All of the cabling is CAT5 and the leads to the caps are all the same length. Thus, any aboration due to the length of the wires is the same for all caps under test. I regret not having posted tests results of late. Other demands on my time - family, work, etc. have gotten priority over the tests. I will be posting results of test conducted on a pair of film caps over the next week.
Davet |
#102 |
Hi
Excellent thread Has anyone tested the Black Gate AC. Brent |
#103 |
The Black Gate AC I am using are 50V 6.8uF and 10uF. Both sound pretty much identical to each other.
Brent |
#104 | |
I have been testing WIMA 2.2 capacitors at the suggestion of Keith (KP11520). I have tested these caps that currently have about 8 hours burn-in time on them; compared to caps that have had 144+ hours burn-in on them. Evidently, the caps burn-in quite quickly. The distinct difference I heard when I first tested these caps right out of the box (no burn-in) is not as apparent after 8 hours. Therefore, the following was my initial impression of the WIMAs (zero hours burn-in).
I must say that after 8+ hours on the NIC cap - I no longer make a run for the door. The cap evidently settles comparative quickly. I still hear quite a bit of sibilance on female vocals though on The NIC. This sibilance for the BIC is, virtually, nonexistent. The only real difference I hear between the WIMA BIC and the NIC is in the upper region (highs). There is a certain “sweetness” to the performance from the BIC. I will subsequently compare the WIMAs to other caps previously tested.
Davet |
#105 |
Hi Dave,
It looks like we have ourselves a horserace after all! It's nice to have several choices based on the nuances that our Mod needs! I am looking forward to the info as it is compiled and reported! Thanks for being a good sport and letting your ears do the talking! Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#106 |
Keith,
Each of the various capacitors has its own character. I think it depends on your budget, how the capacitor will be mounted, etc. Each of the capacitors I reviewed has merits and it all depends on what the individual desires as to their ultimate choice. I have only tested one cap whose overall character I wouldn't use. Even then that specific capacitor has a sonic quality that I might choose for listening to specific types of music. I fear any race will come out as a draw depending on your druthers.
Davet |
#107 |
The following only applies to the burned-in (BIC) WIMA MKP-series 2.2 MFD capacitors as compared to other capacitors I have tested. I also have a set of MKP-series 3.3 MFD WIMAs I will write up only if there is a significant difference over the 2.2 MFD caps.
The WIMAs yields the broadest soundstage of any capacitor I have tested. The sounds seem to emanate from a much wider field than the speakers by at least a meter or so. These capacitors also yield the most body – not presence. Bass just sounds much fuller and acoustic string instruments just have a woody tone. Although, there is more body the presentation is not artificial. The bass sounds balanced and is not so pronounced as to be distracting. These capacitors play much louder than any other capacitor I have tested. For those that may have concerns about the Tripath amplifiers being able to drive or play louder; then the WIMA is the cap one should choose. The WIMAs have a certain holographic effect especially on the Mark O’Connor Hot Swing Trio CD. The effect of the violinist swaying back and forth before the microphone is surreal in its life likeness. These capacitors did everything all the other caps did “just” a little better. Only the Auricaps sounded better on large symphonic works. The hall on Pictures at an Exhibition sounds considerably larger when played through the the Auricaps. The WIMAs have a much broader soundstage but the depth is not a great as the Auricaps. I would use the WIMAs for rock, blues, pop, and any electronic based music. This is not to say that these caps are not to be used for classical recordings. I just think that they are better suited to chamber performances or smaller works over symphonic works. On symphonic works thes caps place you one or two rows back from the orchestra – up close and personal. The WIMAs will just move you so much more than the other caps. If you want to become physically involved in the recording this cap is the one. There is some overall sibilance on female vocals compared to the other films but not as much as the Solens. The sibilance would not be noticeable at all if I had not tested other caps. The WIMAs are physically large. Not as large as the Obbligatos, but not as small as the Solens, Auricaps, or Radio Shack films. The electrolytic capacitors are microscopic compared to the film caps. These caps should fit on a TA-10.1, printed circuit board but will pose mounting problems for everthing else. The Auricaps sound somewhat more refined to my ear. This is a personal taste “thing”. I just prefer the overall presentation of the Auricaps. It sounds that the Auricaps just has more air around the performers. The Auricaps are more “relaxed” or laid, back. The performances played through the Auricaps just sound more alive to me. Detail wise the WIMAs leave nothing to the imagination. These caps deliver everything in a big way. The BIC WIMAs measured 2.23 MFD and 2.29 MFD. These caps are 10% tolerance 250 Volt units. The MKP series also comes in 5%tolerance. Cost vary widely depending on tolerance, voltage, and distributor. Select a distributor from http://www.wima.com/EN/distribution_int.htm or perform a web search.
Davet |
#108 |
The attached photograph is of a few of the caps that have been tested. The Blackgate was included for the purpose of scaling the relative size of the various capacitors. In addition there is a ruler in the photo.
Davet |
#109 |
Hi Dave,
Nice work! I am with you that each has a nuance to its own and you may choose certain caps based on what your equipment is missing. My CD Player for instance is nice but kind of cold so the Wima MKP10 and the Obbligato Film/Oil are what I am going to test! I think it is going to be a hard decision and I might also try the Auricaps just to really make the decision really painful! So are you going to change the Output Caps in your CD/DVD Player now too? What about your Preamp? This can really turn into a sickness? I need a nice Steamed Crab dinner and watch re-runs of "The Deadliest Catch," while I am changing the caps in all my equipment! So sad and so exciting! Pass the melted butter, please! Regards//Keith
#110 |
For the moment I will not be changing any of the caps in my equipment. This would alter my test platform. Although, the preamp is not a part of this test platform. I still have a number of test, yet, to perform
The coupling caps in my tube preamp are Auricaps. I don't recall what coupling caps are in my DVD player, but they are not the stock caps. They are either Panasonics or Blackgates. I know I have Auricaps for the Swenson mod, but I never implemented it. I admit I had a bias to Auricaps before undertaking these tests. I wonder if there is a degree of synergy that exist, for there are Auricaps in my speaker crossover, as well. Be forewarned the Auricaps take a long time to break in and settle down - around 200+ hours. Everyone has their favorite cap. I really enjoy all of the films I tested. The various strengths make it hard to like just one. In my "ultimate" T-Amp I will probably include three or more caps with a switch that allows me to switch between them for various recordings. As to steamed crab dinner - you aren't referencing the "Burn-in Crab" are you? It might be a little tough to chew compared to Chesapeake Bay Blue Crabs.
Davet |
| DC coupling circuit for Tripath amps | theAnonymous1 | Class D | 3 | 23rd June 2009 06:08 PM |
| input stage shielding: coupling caps | xiphmont | Chip Amps | 5 | 4th March 2008 12:47 PM |
| Tripath Coupling Bypass Cap Test Bed Query | Davet | Class D | 4 | 9th January 2008 02:12 AM |
| Pre-amp coupling caps | Bill Fitzpatrick | Parts | 15 | 4th March 2005 11:54 AM |
| GC input coupling caps from RS (Europe): any good? | antomas | Chip Amps | 20 | 27th August 2003 06:33 PM |
| Page generated in 0.24656 seconds (51.64% PHP - 48.36% MySQL) with 11 queries |
