Go Back   Home > Forums > Amplifiers > Class D
Old 4th May 2007, 12:17 PM   #1
Default Tracking power supply
This is the positive half of tracking power supply. It represent a buck converter with voltage control mode.
U4 is integrator of square wave 600kHz, resulting in triangle wave with 5.6 v pp.
U3 is error amplifier, with 2 pole and 2 zero compensation network (R12, R11, C15, C14, C35, C14).
R14 determine the amplification of input signal (A=R11/R14=15). R48, conected at -15v introduces a offset in output, coresponding +7.2v at idle (Vcc x R11/R48=7.2v).
U5 is pwm comparator, feeding U1 fast optocuplor (6N137). Because the switching f=600kHz is high (for best transient response), Q12, Q13, M2, M3 form a buffer with sufficient current capability to drive M1 Mos Fet (IRFP260N).
L1, C5, C6, R3 is part of buck converter filter, with aprox impedance of 4.4 ohm.
Old 4th May 2007, 12:18 PM   #2
The prototype:
Old 4th May 2007, 12:23 PM   #3
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Default Good work
Ion,
This is something known as Class-TD[Lab Gruppen Style]
Have you tried the feedback directly into comparator, this will save you from lot of troubles arising from loop stability comprising error amp....[You have to change the phase also to implement it and also the amplitude of the triangle must be reduced to about 600mV to achieve high open loop gain]
regards,
Kanwar
Old 4th May 2007, 12:40 PM   #4
Workhorse's Avatar
A link to Fredos post, explaining how to eliminate error amp...
http://www.diyaudio.com/forums/showt...77#post1104977
Old 4th May 2007, 12:40 PM   #5
Default Question
Feedback before or after LC? Because is ease in one way (before) but not compensating resonance of filter. Also the transient response is different.
Maybe is your turn to present some of your work.
Old 4th May 2007, 12:51 PM   #6
Workhorse's Avatar
Default Re: Question
Feedback After Filter......Take a look at this.. example
Old 4th May 2007, 01:11 PM   #7
Workhorse's Avatar
The Front end section of Monorail Class-TD....
Front opamp is absolute value converter, then comparator...
Old 5th May 2007, 12:55 PM   #8
Workhorse's Avatar
Hi ION,
What about your other prototype???
Kanwar
Old 6th May 2007, 04:18 AM   #9
From my vision, the front end of monorail is too simple. Because RC input for speed-up high frequency interfere with absolute dc converter (non linear in+/-0.65v), because you sense output signal, not floating dc power.
Power disipation on class AB+tracking power, is P=7.5V * I(out), just because power final is polarised with aproxx 7.5 v, for normal operation (+/- ripple).
In monorail, power disipation it's double (2 * 7.5v * I(out)), just because H bridge...
Look at my proposed front-end (sensing diferential voltage, absolute value converter)...
I tryiet to simulate D1200 feedback in OrCAD: no positive result.
Any idea?
Ion
Old 6th May 2007, 05:23 AM   #10
Workhorse's Avatar
Any idea?
Ion
Hi Ion,
I sense VAS signal not output....You absolute value converter takes care of small amplitude signals very well...
The power dissipation could be halved if polarised to 3.5V .....just same disspation as half bridge...but inturns you will get double the slew rate of half bridge....
I have not used Feedback in my monorail tracking amp, but i relied on Feedforward compensation by adjusting the amplitude of Triangular wave in proportion to power rail[not tracking, but the idle one] fluctuations....so simple....
What was your gain setting in sim....it had to be around 5X only...to get good results and manipulate the sensing signal also...to tally the pwm gain with amp gain....
LT Dual Tracking 3A Regulated Power Supply 1.25V to 20V okapi Power Supplies 56 9th July 2010 02:33 AM
tracking power supplies for gainclone steven344 Chip Amps 0 6th February 2006 05:13 PM
tracking and magnetic field power supplies RogerG Power Supplies 2 26th May 2005 07:47 PM
Chip Amp as tracking supply for preamp drdagor Chip Amps 2 10th July 2004 10:53 AM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
Page generated in 0.13002 seconds (74.90% PHP - 25.10% MySQL) with 11 queries
