| Class D Switching Power Amplifiers and Power D/A conversion |
hi everybody.i have to do my university project as soon as possible..i do not have much time..i decided to build a high power (more than 250w rms) 20-20khz full bridge amplifier..because full bridge has advantages..i have 4pieces of ir2110..do you have schematics ..i need help
#2 |
heyy ..is there anyone can help?i bought 36,3volts toroid transformer ir2110 lm311 cd4069 and cd4070..do you have any new ideas to build a better amplifier?
#3 |
Some main components LM360, 2X IR2110, NE5532, 4 X IRFP260...+ a Filter Choke
could led you to build a simple H-Bridge Class-D....with single main supply and 2 aux supplies Here is an Idea...just a block diagram not full circuit.. |
#4 |
thank you..i found and bought 5 pieces of lm360..and i made a triangle oscillator with cd4069..i comparated 30khz sinwave with 300khz triangle.and i saw pwm out.i have to do my amplifier..monday is the last day..best regards
#5 | |
#6 |
hi.it is a bit late cuz my friend post me the photo of oscilloscope late..it is the pwm out.i comparated20khz sin with 200khz triangle..what do you think about this..and how can i put it into the ir2110?which transistor may i use?
thanks for help |
#7 | |
I think i have already posted the diagram in previous post. Use IRFP250N Mosfet as output device..... regards, Kanwar |
#8 |
hi.. i decided to make a self oscillating amplifier with +-47volts..i will use st irf540..why using irfp250?is irf540 not enough..and i dont know how to make a volume control..could you help?do you have any schematic about iraudamp?..thank you
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| how ir2110 drives the high side mosfet in h bridge | gowri | Class D | 2 | 10th April 2008 06:30 AM |
| High side drive in a full bridge( or Half) converter | ifrythings | Power Supplies | 7 | 23rd December 2006 08:41 AM |
| Power Supply Pumping with full bridge | edogd | Class D | 1 | 3rd February 2005 08:02 PM |
| Whats the difference between full bridge and half-bridge SMPS ? | skaara | Class D | 6 | 3rd February 2005 07:23 PM |
| Page generated in 0.27588 seconds (27.86% PHP - 72.14% MySQL) with 11 queries |
